HC- emissions test failed - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 11-17-2008, 09:23 PM Thread Starter
Date registered: Jun 2008
Vehicle: 124--- 1991 300 CE
Hey everyone--
My emissions test failed. I have a high HC at the 25 mph test. ( I thought that it was the nox in my last post --- my bad) The HC was 205. I need it to be 184. Does anyone know if I add denatured alcohol to the tank and then drive it for about 30 min and then take it to have it re tested. Will the HC pass? Will it lower the HC?
Should I change the oil? Some of you mentioned it would help.
What would it do if I changed the spark plugs. My mechanic changed them a while back and said they would last until my mileage was around 170,000. My car has around 132,000 right now.
mercedesgirl300CE is offline
post #2 of 2 (permalink) Old 11-20-2008, 02:05 AM
jboymagno's Avatar
Date registered: Sep 2008
Vehicle: 2000 e240 facelift
How about change engine oil, air filter, tune up and clean if not change your spark plugs!
jboymagno is offline
    Emissions -Failed RANunes W163 M-Class 10 10-08-2007 10:38 PM
    Emissions failed... jkinsey W123 E,CE,D,CD,TD,TE Class 12 11-22-2006 04:11 PM
    1990 300SE failed emissions test 126Runner General Mercedes-Benz 1 05-12-2006 08:33 PM
    Failed Emissions saporter W201 190-Class 3 01-07-2004 04:57 AM
    Failed My F@#%in' Emissions Test!!! Mike G. G-Class 15 01-30-2003 07:07 PM
