Transmission Heat - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 11-14-2008, 09:57 AM Thread Starter
Date registered: Nov 2008
Transmission Heat
I have a 2001 s430 107k on it. Overall a good car and taken car of. Periodically heat comes up through the center console where the gear shift is. It doesn't do it all the time but sometimes. Had it checked out by MBZ and they cant find anything. All heat shields are in place. Only thing I was told is it could be the catalytic converter giving off the heat. Any help would be great.
marketgy is offline
post #2 of 2 (permalink) Old 11-14-2008, 12:28 PM
Musikmann's Avatar
Quoted: 5 Post(s)
I took a stab at your drifting issue on this forum before I saw your 2nd question. You have a W220 and that's probably the best forum to ask questions. Just scroll down from here to the Sedans section and you should see it.
Musikmann is offline
    More floor heat & Lost heat in seat base t28pilot W163 M-Class 8 06-27-2014 09:49 PM
    Heat...Heat (Bridging The Sensor) Haroundb W123 E,CE,D,CD,TD,TE Class 1 03-10-2007 11:56 AM
    screeching noise from transmission when using heat dieseldude W123 E,CE,D,CD,TD,TE Class 4 02-25-2004 06:50 PM
    HEAT! HEAT! HEAT or absence thereof... barry_s_u W126 S,SE,SEC,SEL,SD,SDL Class 8 01-18-2004 08:55 AM
    Heat coming from transmission Greg Avril G-Class 3 12-21-2001 11:02 PM
