ML320 (1998) Electrical Problems - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 11-10-2008, 04:15 PM Thread Starter
Date registered: Oct 2008
I own a 1998 ML320 that has aprox 112,000 miles on it. While I was driving the car, the engine suddenly and without any warning shut off. I stopped the car and attempted to restart it. The AC, fan, turn signals, power windows and power locks also went off. The instrument panel showed no indicator lights except the SRS, no fuel gauge, no temp gauge. There was no check engine light showing and the engine would not restart at all. I could not hear any starter sounds or attempts to turn over the engine when I turned the key in the ignition.
When the tow truck driver arrived, he unsuccessfully attempted to jump start the car.
An automobile electronics shop diagnosed the problem as a fault in the BCM or ECM, but they did not have the equipment to fix it.
A Mercedes repair shop performed an additional diagnosis and found a broken pin on the fuse box (a connector between the AAM and the fuse box) and corrosion where water had leaked in between the fuse box and the AAM.
He stated that I would have to replace the AAM, ECM, fuse box, ignition and locks because all 8 keys available for my ML320 had already been used. The dealership would not just send him a new AAM and fuse box stating that there were no more keys to be programmed on the old equipment. The maximum was 8 keys.
Can anyone confirm the problem regarding an 8 key replacement limitation for the 1998 ML 320?
Is there any way to work around having to replace both the AAM and ECM due to the key limitation?
Is there any way to work with the current keys (reprogrammed?) and avoid replacing all locks and the ignition?
Are there any parts warehouses that sell these electrical parts outside of the dealerships?
SFedyshyn is offline
post #2 of 4 (permalink) Old 11-10-2008, 06:26 PM
Kajtek1's Avatar
Quoted: 1052 Post(s)
I heard the 8-key story before. My understanding is that the mechanical locks can be reused, jut the electronic chips replaced.
I am afraid you are in the mercy of stealers.
Good luck
Kajtek1 is online now
post #3 of 4 (permalink) Old 11-11-2008, 12:15 PM
Send a message via Yahoo to NAPTOWNBENZ
If you just need the AAM , you should be able to order it with a coding key(163 760 14 06)
Not having the car here , its hard to diagnose what they might need. The car might have lost the key track memory.
When you run run out of Key tracks(1-8) YOu need to replace the ignition tumbler, All Activities Module, Engine Control module, and the Door locks.
YOU can duplicate key tracks on other Mercedes-Benz Vehicles.
As far as electronic parts. I am a dealer but I can get you GREAT prices on parts.
Mercedes-Benz of Annapolis
NAPTOWNBENZ is offline
post #4 of 4 (permalink) Old 11-11-2008, 10:08 PM
Diesel Benz's Avatar
Quoted: 32 Post(s)
Can you explain why door locks need to be replaced? I assume it is because MB assumes keys being lost, including the mechanical key then too and they want to gain the same security as for a new car (nobody having the old key for the car could enter it with the metal key even when the remote key is disabled)?
Diesel Benz is offline
    1998 SLK 230 Electrical problems reverendcolin R170 SLK-Class 20 07-18-2012 02:43 PM
    ML320 Electrical Problem. Battery/alternator? bws858 W163 M-Class 4 10-02-2009 02:01 PM
    ml320 electrical problems nyml320 W163 M-Class 6 04-20-2007 10:01 PM
    my 1998 ml320 stefan ml320 W163 M-Class 5 08-17-2006 07:03 PM
    1998 C230 Electrical Issues jrewing General Mercedes-Benz 0 09-09-2004 06:09 PM
