Originally Posted by nsw Don't know if you consider it relevant, but my E320 (see left for more details) actually starts in the 2nd gear when the Sport/Comfort button is set to C (comfort). It works fine. I suppose starting in the 2nd gear (with the C setting) is more suitable for winter conditions. Wish you get better advice from other members. |
Hello..... thank you for your response on the transmission issue.
Since it did not go crunch or clunk or anything I can say sounded bad I am really not to worried as it can be fixed with it not coming out of the car.
My transmission relies on vaccum and is not electronic being a 1981.
I was told it could be a valve body issue with a spring. I am hoping it is that for if I need another auto trans, I will opt for a 5 speed stick Getrag manual conversion.
I am also in the process of converting and making a hydrogen on demand system. I get about 28 MPG in the Summer now, with the 5 speed manual trans that will definitely bump up to 35 MPG or 40 Mpg.
With the HHO system I can seriously see with hydrogen assist around 75 possible MPG.
These are very serious numbers that can be reached.
I have a friend with a "real Hummer"... not a converted new Chevy Tahoe frame 2008 Hummer. He matriculated from a tech school and is a brain at literally everything mechanical, electronic and probably every thing else too.
He has an on board computer with his Hummer and is getting 122 MPG in the city with a diesel, electric, hydrogen assist combo.
His speeds with the Hummer can be as high as 90 MPH, why go that fast.... because he can is the answer.
In town his electric assist takes over up to 40 MPH, then diesel/electric take over, then over 45 MPH hydrogen/diesel assist kicks in.
To see the computer at 70 MPH read close to 90 MPG is nuts.
To take one gallon of bio-diesel.."yes he makes that as well"...and put it in a self bleeding injection system and run from empty to 90 miles and then before it chokes empty switch the solenoid over and run from the tank is crazy. How do I know it runs that well MPG wise? I was the one holding the fuel container that the fuel line came from that went right into the injection. Also I saw the solenoid kick in since that was at my feet when the screen said 90 MPG. If you want to be really technical it was 90.013 MPG. Yes he built the black box computer too for the engine management system.
Hey he is a board certified genius..... I just have a transmission issue and he also thinks it is a spring in need of a change in the transmission valve body too.
