how to fit the supercharger unit 230slk - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 11-09-2008, 07:58 AM Thread Starter
Date registered: Sep 2008
Vehicle: 230 slk Komp
Hi All
Could any one tell me if it is easy to fit a supercharger unit,,as mine has blown its magnetic coupling unit, so managed to get a second hand one.
please help.
Ashv8 is offline
post #2 of 2 (permalink) Old 11-10-2008, 05:21 PM
Date registered: Oct 2008
Vehicle: 1999 slk 230
well if I am understanding you correct, you are trying to remove and reinstall a different supercharger; I took mine off, it is not very hard, you have to be very patient, you need to remove the air filter and part of the supercharger that is attached to the rubber hose, if you do not take off the fan shroud, I don't think you'll be able to take the unit off, don't force it out try wiggling it you need that centimeter space created by removing the ban shroud, to remove the fan shroud you need to remove the recovery reservoir, be careful when you disconnect the plug, I have not put one back yet Ill tell you how that part goes on later, good luck be patient, if you could grain the antifreeze before disconnecting any hoses you would prevent messy garage floor. good luck
shaunt is offline
    used supercharger unit how much? Ashv8 R170 SLK-Class 2 10-22-2008 03:18 PM
    Trying to buy Command Unit. Will it fit? dynomite05 C209/A209 CLK-Class 2 03-10-2008 01:25 PM
    C32 AMG supercharger fit on my 99CLK320? phantomjt3 C208/A208 CLK-Class 5 10-22-2007 12:07 PM
    Nav unit from 04 ML 350 fit 04 e320? jlc1978 Audio & Telematics Forum 1 03-25-2007 12:40 PM
    JVC KD-AVX1 Head Unit...WILL IT FIT DerekJL W124 E,CE,D,TD Class 2 06-16-2005 08:06 PM
