Fan - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 11-08-2008, 01:05 AM Thread Starter
jboymagno's Avatar
Date registered: Sep 2008
Vehicle: 2000 e240 facelift
Fan
Is it normal that the engine fan rotates slowly while the engine is still cold? Then rotates faster when the engine gets hotter. Is there a sensor thing involve here?
Compared to Japanese cars the situation is different.
jboymagno is offline
post #2 of 3 (permalink) Old 11-08-2008, 05:32 AM
Diesel Benz's Avatar
Quoted: 39 Post(s)
Thank God that isn't the only difference between MB and (some) Japanese cars.
You are probably referring an electric fan to a belt driven fan with a visco clutch.
Diesel Benz is offline
post #3 of 3 (permalink) Old 11-08-2008, 06:02 AM
pmark3100's Avatar
Vehicle: 1982 M-B 380SL, 1998 Ford Taurus, 2001 Dodge Ram 2500, Kawasaki ZG1000 Concours
It's a fluid clutch function. When the engine os cold or you're going down the road and a lot of air is blowing across it, the clutch in the fan disengages to release more power from the engine to moving the car. As the temperature goes up, the clutch tightens and pulls air in. This technology goes back a good 40 years or so. If you're ever next to an over the road truck at a light, you can sometimes hear the fan kick in with a roar. It sounds like an aircraft taking off.
pmark3100 is offline
    Head gasket leveled, New Radiator, new Thermostat, New fan clutch, both Auxiliary fan Workersvillage W124 E,CE,D,TD Class 11 08-10-2008 10:32 PM
    engine fan or radiator fan fuse and relays ?? DnBtekhnic W203 C-Class 0 04-21-2008 08:40 AM
    Aux fan run when Engine fan runs? Is it possible? Haroundb W123 E,CE,D,CD,TD,TE Class 48 07-22-2007 08:17 AM
    Replacing clutch fan for thermo fan... baskarz W126 S,SE,SEC,SEL,SD,SDL Class 0 04-10-2007 09:02 PM
    126 HVAC Fan not working / Heater Fan Removal cam69ss W126 S,SE,SEC,SEL,SD,SDL Class 1 01-25-2005 10:31 AM
