Help- Climate Control Issues - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 11-03-2008, 11:19 AM Thread Starter
Date registered: Nov 2008
Vehicle: 1987 Mercedes 300D
Post Help- Climate Control Issues
I'm having climate control issues on my 1987 300D and need help. My air conditioning was running and all of the sudden the air became extremely hot so I tried to turn the system off but the off button would not work so I stopped and turned off the ignition. I few minutes later I turned the car back on and the air conditioning was cold as usual. About 5 minutes later the air turned extremely hot again and I had to turn off the ignition. I took it to my mechanic and the climate control unit was replaced as well as the mono value.
This is my problem: the air conditioning does not come on and in fact no matter where you set the temperature wheel its HOT, HOT HOT! When you turn it off the air flowing through the top vents is so hot you can literally burn your hand. If its not a defective mono value, what suggestions do you have for the problem? I don''t think it''s the air compressor (I hope) but I don''t know the components that might be involved.
I sure hope someone out there has seen this problem.
300dbenzer is offline
post #2 of 6 (permalink) Old 08-13-2009, 08:48 PM
Date registered: Sep 2006
Did you ever find out what the problem was with this? Mine does the same thing.
tisdale36 is offline
post #3 of 6 (permalink) Old 08-13-2009, 09:16 PM
slammer111's Avatar
Date registered: Dec 2004
How about a faulty or loose temperature sensor somewhere in the car? Maybe it always reads -20C or something. That would make the car try to crank up the heat.
2003 CL230K Orion Blue auto, panorama, rain sensor
slammer111 is offline
post #4 of 6 (permalink) Old 08-13-2009, 11:27 PM
Where is temp sensor? I know it has to be in the cabin somewhere but where? It is unbelievably hot air coming out of vent. So hot I cant drive it. It would work nice in Antartica or something but not Texas.
post #5 of 6 (permalink) Old 08-13-2009, 11:41 PM
Date registered: Jan 2007
Vehicle: Mercedes 200TE
Usually behind some small unassuming grill, in my W124 and my W210 they are both near the interior light on the ceiling.
Just thinking though, the actual sensor may be behind the dash as in the W124 there is a pipe going from the grill down to the fan behind the dash so the sensor could be anywhere along that path. If you aren't confident taking things apart then I'd get a technician involved.
Stu2000 is offline
post #6 of 6 (permalink) Old 08-17-2009, 12:11 PM Thread Starter
Climate control issues
I did find out the problem....it has to do with vacuum lines.(Imagine that) I believe there are 4 lines in the climate control system and 2 of the lines had a problem. My mechanic cut those lines off and told me it may last a week or I may never have another problem. If it didn't work he said we would need to replace all of the lines including the bad ones since he would already be in there. To date I have had no further issues and the system is heating and cooling just fine. Iwas lucky in that he found the problem rather quickly. The line tracing could have taken a while but my mechanic is tops!!!!!
Hope this helps you out.
    Climate Control Issues yoyomoefoe W140 S-Class 1 10-29-2008 10:19 AM
    Climate Control Issues kats24 C208/A208 CLK-Class 2 01-30-2007 09:05 AM
    Climate control issues????? Darkmann W163 M-Class 2 12-26-2006 04:13 PM
    Climate control Issues Tbilisi79 W140 S-Class 2 01-07-2006 02:47 PM
    climate control issues mark30H W201 190-Class 5 04-19-2005 08:07 PM
