Backward rotation-damage? - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 10-31-2008, 06:41 AM Thread Starter
Date registered: Aug 2008
Vehicle: 1981 300CD and 1982 240D
Question Backward rotation-damage?
What are the consequences of rotating the engine counterclockwise (backward). Will this damage the engine? During valve adjustment, rotation was turned backward several rotations. Can I just proceed adjusting valves with clockwise rotation, or has the error created problems that should be addressed before continuing valve adjustement and statring the engine?
reynoldsd is offline
post #2 of 3 (permalink) Old 10-31-2008, 12:28 PM
Date registered: Oct 2008
Send a message via Yahoo to NAPTOWNBENZ
Its not adbisable, but as long as you can return it to where it was , it shouldn't be a problem.
NAPTOWNBENZ is offline
post #3 of 3 (permalink) Old 10-31-2008, 02:06 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
If you rotated it backwards by hand, you probably have not damaged anything, but as noted it's definitely NOT advisable.
Before you proceed with adjusting the valves, I would turn it over in the proper direction a couple of full revolutions to ensure tension and slack are in the correct order again. You could do that after as well, just make sure you do it before you start the engine, otherwise the sudden jerk on everything could have less than desirable consequences.
Take care and enjoy the ride,
Check Codes is offline
    Motor off/in gear/rolled backward kabory General Mercedes-Benz 4 09-03-2008 08:30 PM
    Giant leap backward Botnst Off-Topic 12 02-13-2008 07:51 PM
    Tire Rotation jasonryan11 R171 SLK-Class 9 06-10-2007 05:03 PM
    tire rotation...... paperhoward W124 E,CE,D,TD Class 3 07-25-2003 11:29 PM
    Do the stock 3rd row seats face forward or backward? Edmund Lewis W163 M-Class 3 12-24-2001 09:31 AM
