I need to find a vacuum steered valve that regulates gas flow into the carb:Solex 4A1 - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 10-30-2008, 08:25 AM Thread Starter
Date registered: Oct 2008
Vehicle: 1973 280 C
Question I need to find a vacuum steered valve that regulates gas flow into the carb:Solex 4A1
Hi, Hoping that someone can tip me off as to where I can find a valve between the fuel pump and the carb and steers the gas amount into the carb (with a 'excess' return line to the tank). The part is connected to the carb thru a brass tube with nut and regulated by a small vacuum hose from the carb. I don't know the name but I believe the parts nr to be A0000720417. Alternatively, is it possible to adjust the idle/gas flow without having this part or by using another from another model that one modifies ? Hopeful for a helping hand in solving this, as the carb now gets way to much gas and it isn't possible to adjust the idle properly (really at all). fred
fred m is offline
    4A1 solex carb data teky General Mercedes-Benz 1 11-13-2014 03:36 PM
    Infamous Solex 4A1 Dlespera W126 S,SE,SEC,SEL,SD,SDL Class 6 11-12-2008 11:56 AM
    Infamous Solex 4A1 Dlespera W123 E,CE,D,CD,TD,TE Class 4 07-30-2008 03:49 AM
    Where's are the damn idle screws on my Solex 4A1? 73280Sedan Vintage Mercedes-Benz 5 10-17-2006 07:59 PM
    TN starter on Solex 4A1 Carb - W123 250 Saloon 1984 iwebst2 W123 E,CE,D,CD,TD,TE Class 3 01-27-2006 08:56 AM
