1993 190e timing chain guide - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 10-26-2008, 07:53 PM Thread Starter
Date registered: Oct 2008
Vehicle: 1993 190e 2.3
I am removing the cylinder head from my 1993 190e 4 cyl
I need to remove the timing chain guide to free the timing chain and remove the head. the gude is held by two places and not sure how to remove these pins? Are they pulled out by a puller or do they screw out?
MARK190e is offline
post #2 of 2 (permalink) Old 10-27-2008, 03:11 PM
MTI's Avatar
Vehicle: '85 2.3-16 '99 C280 '11 GLK350
The plastic chain rail guides are held in with pins that are pushed in, not screwed. You'll need to use a slide hammer, threaded into the threaded hollow pin and tap it out via the slide. Some have fashioned their own DIY tool using a long threaded bolt with washer and a drive socket acting as the slide.
MTI is offline
    3.0 Timing Chain Guide Rail Evan W124 E,CE,D,TD Class 8 06-13-2012 08:22 AM
    Timing Chain & Guide Replacement Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 22 07-14-2011 09:37 PM
    Broken Timing Chain Guide Rail.. HELP! Rokkett450SL R/C107 SL/SLC Class 2 07-08-2007 02:17 PM
    Timing Chain Guide Rail BNZ W126 S,SE,SEC,SEL,SD,SDL Class 3 03-23-2006 06:15 AM
    Timing Chain Guide Rail Replacement Litton W126 S,SE,SEC,SEL,SD,SDL Class 1 12-02-2002 08:43 PM
