E320 Check Engine light-Limp Mode? - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 10-23-2008, 06:07 PM Thread Starter
Date registered: Sep 2008
Vehicle: Mercedez Benz E320
Unhappy E320 Check Engine light-Limp Mode?
I have a 2001 E320. Check engine light came on suddenly on highway and car shut off and went on in limp mode. Car starts fine but 'gears jumps hard' btwn shifts. Flushed transmission only a few months ago, gas cover tight. if engaged to 'D', wont go back to "R" unless I turn off the switch.Shift from 'D' to 'R" very rough and hard and In have to hot my brakes tight even with car in stationary position.
Mileage is 82K. No codes as I do not have code reader and do not want to spend 2K at the dealership.
What are the possible causes, how can I fix it and is it worth investing on an OBDII scanner? Could this be a transmission problem? Conductire plate?wiper/oil sensor?etc.
No aware of any bad gas or spillage. any advice is appreciated.
jchumba is offline
post #2 of 2 (permalink) Old 10-25-2008, 08:30 AM
CLK3.GS3's Avatar
Date registered: May 2004
Vehicle: CLK,SLK
Send a message via Yahoo to CLK3.GS3
Head over to the W210 boards for help, also try using search for instant answers, you find someone else has had the same problem.
W208CLK/R170SLK
CLK3.GS3 is offline
asr light and limp mode kaju W140 S-Class 11 05-12-2011 03:07 PM
ASR Light comes on and car goes into Limp Mode masaki@japan R129 SL-Class 51 05-02-2009 01:34 PM
01 e320 in Limp Mode please help mpalic W210 E50 AMG, E55 AMG 3 10-25-2008 09:52 AM
How to check code for check engine light 94 E320 W124 Synd W124 E,CE,D,TD Class 1 05-24-2007 02:37 PM
5 spd auto in limp mode .. should it light the CEL? AlanMcR W140 S-Class 1 07-23-2004 03:15 PM
