Bad Black smoke and Knocking after filling up with suspected contaminated diesel - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 10-16-2008, 09:16 PM Thread Starter
Date registered: Oct 2008
Help
Hi all may I start by saying thank you for such a wonderful forum and fantastic info. I have been reading these forums a lot and have learned more that I thought was possible.
My Car: 1984 Mercedes 300sd Turbo Diesel - 126 body California model (I think)
History: I bought this beauty a month ago for $2000 and spent about $2000 and 2 weeks solid on the following.
* New tires and rims
* After trying to get an alignment needed new steering rod arms, done + Alignment
* New front brake assembly - The front brakes were shot and on inspection it was apparent there was 1 x 126 front brake assembly on the left, and 1 x 123 front brake assembly on the right, so I had to have that sorted out and got it all back to uniform and new pads.
* Changed transmission filter, fluid and gasket
* Changed power steering filter and fluid
* Changed Oil filter and oil
* Changed primary and secondary fuel filters
* Changed all V-Belts
* Oil pan gasket
* Diesel purge with Lubo Moly
After all this she was driving great. Starts first time, without any acceleration, No smoke, perfect idle and very little noise. Great power even on hills, and was an absolute treat to drive.
I added 5 gls of Veggie oil (New and clean from Costco) and 10 gls of Diesel and it ran and sounded even better for a week. So quiet and so clean it was just amazing to drive and I got excellent mileage. I took her on a road trip to LA and it was great until on the way home I stopped off for some fuel in a out of the way service station and within minutes I noticed a cloud of smoke following me? I figured it was perhaps mist or condensation as it was a bit of a cold night and continued to drive the hour home back to San Diego. The next day in the light of day I noticed that there was a LOT of black smoke coming out of the exhaust and a loss of power, especially on load (ie: going up hills) and even more smoke.
I suspected it was contaminated diesel and after talking to a friend he said it sounded like I got a bad batch of Diesel and could dilute it out so I removed the return fuel line into a jerry can and drained most of the fuel out and filled up the tank to 1/2 and then attempted to drive the bad fuel out. I have been driving the freeways around my home for 2 days now and the smoke seems to come and go from Terrible to just bad. I got to almost empty again and again filled it up to 1/2 with good fuel as to dilute it but it is now two half tanks on good fuel and it hasn’t really helped at all.
Now: Starts really badly and I need to rev it just to start it up. Lots of black smoke that seems worse of a night time but it might just be an illusion and definitely worse under load or hard acceleration. Loss of power, like down to 40 mph on hills that I use to roar up doing 70. A loud knocking noise at idle and low speeds. Increase in Temp with the temp gauge going well above the 80 mark where it use to never move above this.
On the freeway, on the flat, doing 70 she seems to run quiet and minimal smoke and almost for a moment or two seems to be ok.
I am at my wits end and almost ready to give up. I really don’t know what to do. Most of the work above I did myself, learning from these and other forums so I’m fairly mechanical and handy but have no real experience with diesel engines or Fuel Injectors.
Is it possible that it was not contaminated diesel but just a total coincidence that something occurred around the time I filled up? Or have I done damage to the engine / Injectors by driving it in this condition? Or .....or.....or.....is it something all together different.
Please Please Help as I really need some help and advice on this. I have read that it is not that hard a job (timely yes) replacing the injector nozzles but I don’t want to go through all that if it isn’t the issue
Sorry for such a long blurb but I just wanted to be as detailed as possible.
Again Thank you all so much and any information, advice or experience as it is greatly appreciated.
Cheers James
vegioilpokertour is offline
post #2 of 10 (permalink) Old 10-16-2008, 10:00 PM
Kajtek1's Avatar
Quoted: 1248 Post(s)
Contaminated diesel? With what? Unless it is water -diesel can run on almost anything.
I would replace fuel filter just to start (saving the old one that might be good). Veggie oils softens the orings, so check the fuel system for possible leaks. Those are hard to find since on diesels leaks means vacuuming air into the line. Do you have a clear line where you can observe fuel going to the injector pump?
Next step would be getting infra red thermometer and check if each cylinder is having the same temperature (withing 20F). Colder cylinder would indicate leaky, or clogged injector, or bad valve.
Welcome to the forum and Good luck.
Kajtek1 is online now
post #3 of 10 (permalink) Old 10-17-2008, 11:18 AM Thread Starter
Thank you for you advice and info. I am leaning towards clogged injectors and I have ordered new Nozzels and fuel lines.They will be here on Monday so ill reply with the results either way. Fingers crossed this will resolve the issue.
post #4 of 10 (permalink) Old 10-19-2008, 09:51 PM
TechGuru's Avatar
Vehicle: 1988 M-BENZ 300E | 1991 FORD PROBE GT TURBO | 2003 FORD EXPLORER 4x4
Quoted: 13 Post(s)
If I remember my diesel knowledge correctly I think black smoke means too much fuel not not-enough fuel.
Can you hear the turbo spool up when trying to go up a hill? Perhaps the turbo died.
TechGuru is offline
post #5 of 10 (permalink) Old 10-21-2008, 03:35 PM Thread Starter
oil on the bottom of the injectors ?? Help
Not sure about the turbo sound, even when it was going great I could NOT really hear any noise when i gunned it or accelerated under load. It just hummed along fine and fairly quiet (back in the good days)
The new nozzles arrived today and it was a easy pleasant job replacing them. The old nozzles were in bad shape and very clogged up with black soot/mess. Following Diesels Giants walk through I thoroughly cleaned the injectors and installed the new Nozzles.
One thing i noticed when i removed the injectors was that they had what appeared to be black engine oil on the bottom of them where they screw into the engine block. From this I can only deduce that either the piston rings have blown or the head gasket/head is blow/gone letting oil get into where it is not meant to be. Would this be consistent with the knocking, loss of power, and thick black smoke from the exhaust? Do you think i have gasket/head/ring issues or is this normal (I cant imagine)
Thank you for all your help info.
post #6 of 10 (permalink) Old 10-21-2008, 05:07 PM
TechGuru's Avatar
Quoted: 13 Post(s)
Oil usually makes blue smoke.
Normally...
Black Smoke = Too Much Fuel
Blue Smoke = Burning Oil
White Smoke (Actually Steam) = Water Getting Into Combustion Chamber.
Could be that one or more cylinder's has lost compression causing the diesel being put in it to just smolder instead of igniting. Just for the hell of it, check your glow plugs.
TechGuru is offline
post #7 of 10 (permalink) Old 10-21-2008, 05:21 PM
Mercedes Benz of Florida's Avatar
Date registered: Dec 2006
Vehicle: 2000 Mercedes-Benz S500. Sold: 2000 C230K, Sold: 1997 Porsche 944S
Quoted: 26 Post(s)
Send a message via Yahoo to Mercedes Benz of Florida
And what about him running some Lucas Diesel Fuel Conditioner?
That neutralizes poor/bad Diesel Fuel.
Do you recommend this?
I guess it would not hurt.
I use Lucas Fuel Conditioner for my Gasoline powered Car.
Normally...
Charles
New York City, NY
Richmond County
United States of America
Mercedes Benz of Florida is offline
post #8 of 10 (permalink) Old 10-21-2008, 05:27 PM Thread Starter
Hi thanks for the reply
Its definately BLACK smoke = To much fuel ? If this is the case what is the solution ?
I am going to do a compression test on it tomorrow if I can. I have borrowed a compression tester from Auto zone but not to sure at this stage how to go about it. Gonna Google it and find out.
Also with the glow plugs, what is the best way to test them. Just remove them and Inspect ? And how could the glow plugs cause problems like this ?
Again thank you for all and any information
cheers James
post #9 of 10 (permalink) Old 10-22-2008, 09:53 AM Thread Starter
Ok almost there I think :)
Ok the new nozzles are in and at freeway speed she is running great and has excellent power and acceleration.
At idle she is still a little rough and very smokey. I think at freeway speed it still smokes quite a bit also but runs and feels really smooth.
So now I think I have some IP timing issues and I have read one of the more common reason for this in old Mercs is the slight stretching of the timing chain.
My question is this. If I am thinking of replacing the timing chain anyways (as I have recently bought the car with NO history of maintenance and have spent quite some money so far doing other repairs and maintenance) will this fix the IP timing issue, or will I still need to do this after the chain has been replaced.
I think I can fairly easily do the timing chain replacement but from what Ive read adjusting the IP timing is another battle in itself.
Thank you
post #10 of 10 (permalink) Old 10-22-2008, 10:33 AM
TechGuru's Avatar
Quoted: 13 Post(s)
Sounds like the old nozzles were putting out a stream instead of a spray/mist.
TechGuru is offline
    Filling tank with diesel klausc X164 GL-Class 11 03-18-2013 04:46 PM
    1985 500sl Black smoke and a black substance YLIANADIAZ R/C107 SL/SLC Class 5 09-14-2008 02:25 AM
    Diesel knocking please help RedFar W123 E,CE,D,CD,TD,TE Class 4 12-29-2007 01:18 PM
    Black Smoke from diesel neemhakim W123 E,CE,D,CD,TD,TE Class 12 08-31-2007 05:18 PM
    Bad Knocking az2md W210 E-Class 0 09-15-2003 07:56 PM
