Carsoft software help!!! Please!!! - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 10-14-2008, 01:22 PM Thread Starter
Date registered: Jul 2008
Hi, Ive just bought some mercedes diagnostic software off ebay shown here im using it a usb to RS232 cable because i dont have the right port on the laptop, i can load the software up and everything and it all seems like its working but it always comes up with something like "module not built in or not responding" does anyone know how i can get around this please? I'm using it with the 38 pin cable on a E230 W210 model,many thanks
boyracer_xr2 is offline
post #2 of 7 (permalink) Old 05-15-2009, 08:14 AM
Date registered: Jan 2009
I'm having the same problem on my w210 E230 s well. I think the problem might be the software is not cracked to work with K-line. Is there a separate crack for K-line or am I looking in the wrong direction?
Gizmotech is offline
post #3 of 7 (permalink) Old 05-15-2009, 09:13 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Hi, Gizmo. If you do a search you will find lots of posts on this topic.
Most of the time it is the adapter, many, many things designed for a dedicated COM port don't play well with USB adapters.
Get a PCMCIA to COM adapter and those seem to work well.
That said I don't know what you mean about K-line?
Take care and enjoy the ride,
Check Codes is offline
post #4 of 7 (permalink) Old 05-15-2009, 09:47 AM
Hi, thanks for your reply. What I meant by the K-Line is that my interface came with a pirated copy of the Carsoft 7.4. On the readme it said:
"Software is tested with original interfaces and cloned interfaces, this is not a K-line crack !"
Now I'm assuming my 1996 Mercedes E230 UK Spec is most probably a K-line as I definitely know that it is not a CAN system and assuming that it is K-Line as the softwares not working.
I've read that other people have tried PCMCIA Serial port and have the same problem. I know the 38 pin cable supplied is a cheapy version as it has only 3 wires connected to the pins (I opened it up). Therefore I can understand if it does not connect to ABS, Airbag, EPS and other systems, however looking at the Carsoft Pinouts, it looks like that it is connected to the HFM (ECU) line.
No have I got a faulty ECU or is the Software not good enough or is it a matter of the serial port being a USB converter cable. I'm in between whether I should spend more money on a decent 38pin cable and a PCMCIA serial port card or just to give up as my budget is very limited.
Any advicewould be great even if thre is an alternative software out there that I can use on the Mercdes Multiplexor, that would be brill. Thanks.
post #5 of 7 (permalink) Old 05-04-2010, 11:36 AM
Date registered: Jan 2010
Vehicle: 2000 C230 Kompressor Sport Edition, 1999 SLK230 Sport Edition, 1977 300D.
Make sure your Carsoft is reading the right com port.
Cal777 is offline
post #6 of 7 (permalink) Old 05-04-2010, 12:25 PM
e-420's Avatar
Date registered: Sep 2008
Vehicle: 1997 E-420 (150K miles), 1997 SL500, (90K miles) 2015 GMC Sierra Denali 2500HD CC/SB/4x4 Duramax
Quoted: 351 Post(s)
Only sure fire solution is to use it with a laptop with a built in RS232 port, e.g. an OLD, no ancient, laptop. I knew there was a reason I kept that old laptop!
PCMCIA RS232 port is hit and miss. I sometimes works on mine but not predictably.
USB-RS232 adapter is miss and hit. It might work sometimes if the phase of the moon is right and you made the right sacrifices to the PC Gods.
Mine has all the K-Lines pins connected and a muliplexer box that connects the approriate pin to the RS232 port
humm... wonder if OP is still around, post is 2 years old!
97 SL500 Imperial Red
/Parchment Leather/Black Top
Chromed OEM wheels, Akebono's, H1+90 fog, Burlwood/Leather shift knob, Rostra Lumbar support, Check seat heaters, Bilstein's, Parrot Bluetooth, GG Bailey Custom cargo mat, GG Bailey trunk mat, Real Burlwood Instrument Cluster w Chrome rings, Burlwood & Chrome shift surround, Euro headlights with Osram 70W/65W H-4's, clear corners, Silverstar corner lamps, Euro Trunk mount Warning triangle, SL600 Burlwood armrest trim & Burlwood cupholder sliding cover, Kahtec flashing third brake light (CHMSL)
97 E420 Royal Indigo/Grey Leather
Raintracker wiper, Rostra Lumbar support, Parrott Bluetooth, 17" chrome AMG replica wheels, Bilstein's, Akebono's, smoked marker lights, Osram 65W H7's, H1+90 fog, Rear Seat Child restraint Tether, Burlwood/Leather shift knob, OEM Mudflaps, DRL's, Becker Aux input
e-420 is offline
post #7 of 7 (permalink) Old 05-05-2010, 05:13 AM
I never was able to get it to work. I think it may have not been compatible with that model year or model. In the end I sold the interface and got rid of the car as I was without a car for too long. Thanks you guys for all your help and keep this thread open as it may help others even though not me.
    I have some Mercedes Star Diagnosis software, DAS, WIS, EPC software etc for sale on ebay aquascape R171 SLK-Class 17 01-03-2012 12:41 PM
    Carsoft ME software version Biosphere R170 SLK-Class 5 10-02-2008 08:46 AM
    CarSoft Diagnostic Software on pre OBDII odin369 W140 S-Class 2 03-14-2008 08:29 AM
    WIS and Carsoft software rufus V-Class 4 01-05-2007 06:06 AM
