Are the V8s underpowered? - Page 2 - Mercedes-Benz Forum
post #11 of 17 (permalink) Old 10-08-2008, 10:05 PM
nlehre's Avatar
Date registered: Feb 2008
Vehicle: 2005 SL500, 2011 GL350
Horsepower doesn't tell the whole story. Mercedes tunes the engines to deliver high torque readings. For example, the E550 makes 381 horsepower and 391 ft-lbs of torque. It's the torque that give you the office-the-line performance. They could tune for higher horsepower at the expense of torque. This also allows for an unstressed engine and long engine life.
Neil
San Francisco Bay Area
2007 E550, P1, Sport
1996 SL320, ASR, Heated Seats, Xenons, CD Changer,
My Cars: http://www.benzworld.org/gallery/sho...&ppuser=133412
nlehre is offline
post #12 of 17 (permalink) Old 10-08-2008, 10:10 PM
mcbear's Avatar
Date registered: Apr 2004
Vehicle: E500Es
Originally Posted by randian View Post
No. It's easy to get big HP numbers if you can rev the engine at 13,000 RPM. Can't do that with a car engine. Well, you could, but its MTBF would be less than a day.
Mercedes' V8s have comparable redlines to their V6s and should get fairly comparable HP/liter numbers. By way of comparison, the Lexus V8 also makes 380HP, but from only 4.6L. Both the Lexus V8 and Mercedes V6 are direct injection engines, which is why they're so powerful, but for no clear reason the Mercedes V8 wasn't updated (which I expected, since that's what MB usually does). Perhaps Mercedes is going the way of BMW, replacing its big V8 with a ~4L twin-turbo engine like in the new 7 Series, so they didn't want to bother spending money upgrading it. That makes me wonder why they bothered spending the R&D dollars on the V6, if as the other poster suggested they're going to an all-turbo lineup in less than 2 years.
They spend the R&D dollars on the V6 as it will be the BIG motor in the near future. For the C and E it will most likely be the only big NA motor in the lineup. Everything else will be blown to some level, either smaller or built off that block.
McBear,
Kentucky
Being smart is knowing the difference, in a sticky situation between a well delivered anecdote and a well delivered antidote - bear.
mcbear is offline
post #13 of 17 (permalink) Old 10-08-2008, 10:11 PM
nlehre's Avatar
By the way, the Lexus website shows the GS460 only making 342 HP and 339 ft-lbs of torque.
So with the E550 doing 0-60 in less than 5 seconds and the quarter mile in the mid 13s, it can hardly be called slow. These numbers compare favorably with some high-price dedicated performance machine.
Neil
nlehre is offline
post #14 of 17 (permalink) Old 10-09-2008, 01:08 AM Thread Starter
Date registered: Oct 2008
I was thinking of the LS460: 380 HP, 367 lb-ft of torque. It's rather amusing that their "sporty" sedan makes less power than their luxury sedan. In another bizarre move, the sport suspension is only available on the long-wheelbase LS460.
randian is offline
post #15 of 17 (permalink) Old 10-09-2008, 09:24 AM
MB-SV's Avatar
Date registered: Nov 2007
Quoted: 77 Post(s)
Other than the G-class, where is the old low output SOHC 3 valve V8 engine still used? The new modern DOHC 4 valve variable valve timing V6's and V8's all have relatively high output per liter of displacement.
S.
2013 Mercedes C250 Sport package PLUS steel gray metallic/black
2007 Lexus IS350 Sport package smoky granite mica/gray (+F-Sport, etc.)
2010 Honda Civic GX (CNG) white/tan
MB-SV is offline
post #16 of 17 (permalink) Old 10-09-2008, 04:53 PM Thread Starter
The new V6 has direct-injection, which the V8 lacks. Adds 10+% more power and better fuel economy. Another 40-50 HP on the V8s would be mighty fine.
randian is offline
post #17 of 17 (permalink) Old 10-09-2008, 05:53 PM
MB-SV's Avatar
Quoted: 77 Post(s)
Which V6 has direct injection today (not the one in new 09 SLK350)? That would be a nice upgrade for sure.
S.
MB-SV is offline
    S280 Underpowered? BenzW113 W140 S-Class 4 04-27-2008 02:44 PM
    Very underpowered, even for a six... 300se126 W126 S,SE,SEC,SEL,SD,SDL Class 11 06-06-2007 09:52 AM
    R500 is underpowered emayer3 W251 R-Class 6 09-20-2005 06:02 AM
    V8s and LPG heckflosse R/C107 SL/SLC Class 5 09-19-2003 01:17 PM
    V8s - Unleaded and LPG heckflosse W126 S,SE,SEC,SEL,SD,SDL Class 0 09-18-2003 12:33 AM
