Oxygen sensor location - 2000 E320 - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 10-07-2008, 02:16 PM Thread Starter
Date registered: Oct 2008
My P0141 heater circuit failure, Bank 1, Sensor 2 OBD code indicates a need to replace my O2 sensor "downstream" from the catalytic converter. How do I find it?? From the engine compartment I can see the right & left sensors on the exhaust manifold but where are the others?? I am correct that it is somewhere on the passenger side?
BellevueBenz is offline
post #2 of 3 (permalink) Old 10-10-2008, 04:20 AM
CLK3.GS3's Avatar
Date registered: May 2004
Vehicle: CLK,SLK
Send a message via Yahoo to CLK3.GS3
You're in the wrong section, head over to the E Class side of this page for quick answers, also use the "search" feature for immediate answers. Your issue has likely been discussed. Just search the terms you listed but also ask your question on the W210 board. Good luck.
CLK3.GS3 is offline
post #3 of 3 (permalink) Old 10-12-2008, 03:57 PM
Date registered: May 2005
Vehicle: '07 GL320CDI
You have cat converters on the pipe from each side of the engine.
There's an O2 sensor before and after each cat. In the exhaust pipe, of course.
If you think that's you're problem, you're very likely mistaken, however.
Lot's of times it's the MAF sensor, and of course if that provides an improper mixture all kinds of things downstream can present errors.
Kent Christensen
'07 GL320CDI
lkchris is offline
    OXYGEN SENSOR LOCATION? nitrous21 W124 E,CE,D,TD Class 5 04-08-2011 05:54 AM
    Oxygen Sensor On '97 E320 .::Ğї::. W210 E-Class 5 11-16-2007 07:29 AM
    Oxygen Sensor Location 94 S320 m4411b W140 S-Class 0 06-02-2007 10:23 AM
    Oxygen Sensor Location European 1986 2.3 16V pepsimax W201 190-Class 2 06-04-2004 05:53 PM
    97 E320 oxygen sensor smazur General Mercedes-Benz 1 05-18-2004 11:49 AM
