Am I being ripped off? - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 10-02-2008, 09:56 AM Thread Starter
Date registered: Nov 2007
Hi guys,
I just bought a 92 600sel and was told the following needed to be done but I cannot tell if I am being ripped off or not. Maybe you guys can help me decide if I am or not please. This is the list of parts, with prices and hours. Thanks for helping me.
1 Thermostat and drain coolant: 1hr labor plus $88.00 part
1 Temp sending unit: No labor and $25.00 part
1 Temp sensor: 1hr labor plus $38.00 part
12 Spark plugs: No labor plus $214.00 parts
2 Air filters: No labor plus $49.00 parts
1 Fuel filter: .75 hr labor plus $51.00 part
1 Battery: .4hr labor plus $145.00 part
1 Serpentine belt: 1.4hr labor plus $65.00 part
1 Steering idler arm: 1hr plus $68.00 part
1 Set front brake drilled rotors: $324.70 parts
1 Set front brake pads: $102.00 parts
1 Set rear brake drilled rotors: $303.74 parts
1 Set rear brake pads: $92.00 parts
3.5hrs labor to do brakes
2 Distributor caps: $440.00 parts
2 Distributor rotors: $154.00 parts
2 Distributor spark shields: $204.00
Labor for distributor repairs: 1.5hrs
2 Rear window regulators: 3.5hrs labor and $374.00 parts
2 Gal coolant: $48.00 parts
Inspection of overheading problems: 3hr labor
Repair left front door panel: 2.5hr labor
Total parts: $2785.64
Total labor: 19.05 hrs
If you guys would please help me decide if this new mechanic is honest or is just taking me for a ride like many and marking the parts up too high and pumping the labor times entirely too much. Thank you so much for helping me out.
TheSantaFean is offline
post #2 of 11 (permalink) Old 10-02-2008, 10:20 AM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 86 Post(s)
I looked up a few prices on autohausaz:
Thermostat: $54
Spark plugs depend on which kind he is planning on using. Is he changing the wires as well?
2 air filter are a total of $22
Fuel filter between $11 and $19
S belt $38
I would look over your engine and decide what you can do yourself. You should also do a search of the w140 forum to see what DIY instructions have been posted for the jobs you have to have done.
What is he charging for labor?
If you update with your location, I am sure other members close to you can recommend a good shop. If you are in Michigan, I can give you a hand if you want to tackle some of the work yourself.
Mike
Michael Pillay is offline
post #3 of 11 (permalink) Old 10-02-2008, 10:25 AM
sleewell's Avatar
Date registered: Sep 2008
Vehicle: 2006 C230
maybe get a 2nd, 3rd opinion? there has to be more than one mechanic in the area.
sleewell is offline
post #4 of 11 (permalink) Old 10-02-2008, 10:27 AM
hamada128's Avatar
Date registered: Jan 2007
Vehicle: 93 190E 2.3, 94 E320 (sold), 01 E320, 99 S320
Quoted: 345 Post(s)
The only part that I think he didn't overprice is the 2 GAL of coolant.
I think he is even charging you for parts higher than the dealer would ask.
Also 3.5 hr for brake job is too much (I guess 1.5 would be more than enough).
hamada128 is online now
post #5 of 11 (permalink) Old 10-02-2008, 10:33 AM
JCFair's Avatar
Date registered: Nov 2006
Vehicle: '00 E430 Sport, '01 SLK320
Wow nice car. We like pictures. The '92 600SEL is a first year W140 S class model. If you post this under the W140 S CLASS forum you will definitely get a better answer. There is also lots of info there to search through. All I can tell you is that V12 models are rare and parts can be rather pricey.
Personally for all the work you are getting done it does not seem out of line to me.
W210 - Black and Black '00 E430 Sport
R170 - Cream and Salsa '01 SLK320
JCFair is offline
post #6 of 11 (permalink) Old 10-02-2008, 11:06 AM
DEVOURS's Avatar
Date registered: Dec 2006
Vehicle: 2006 B 200 .....& Audi A6..
Quoted: 92 Post(s)
If that much work was being done at a Canadian MB dealership, I feel that the cost would be astronomically higher than that.
If you can do some of it yourself, then so much the better.
That is one very long list!!
DEVOURS is offline
post #7 of 11 (permalink) Old 10-02-2008, 12:50 PM
stox's Avatar
Date registered: Dec 2004
Vehicle: 1996 C36, 1995 S500 Coupe, 1985 190E 2.3
Send a message via Yahoo to stox
Is your mechanic's name Ben Dover?
stox is offline
post #8 of 11 (permalink) Old 10-02-2008, 03:27 PM
Kajtek1's Avatar
Quoted: 1225 Post(s)
17 years luxury Mercedes?
That kind of recommendations can be written by Service Adviser without seeing the car and likely it was.
If you are in California, labor and tax would be over 3 grands making total of $ 6,000.
How much is the car worth?
Love the "Inspection of overheading problems: 3hr labor"
They inspect it on the the route to Vegas?
Kajtek1 is offline
post #9 of 11 (permalink) Old 10-02-2008, 03:33 PM
~BANNED~
Date registered: Sep 2007
Vehicle: 99 Merc S420 (80k Mi) 07 Lexus LS460 (21k Miles)
That car needs way too much work, no matter how you price it. Unless you buying the car for $0, then forget about it.
mr.xpowerseller is offline
post #10 of 11 (permalink) Old 10-02-2008, 03:37 PM
sleewell's Avatar
Vehicle: 2006 C230
sounds like they already bought it
sleewell is offline
    Do you think I got ripped off? Mark600RRBryant R170 SLK-Class 6 09-19-2005 12:33 PM
    Help please...I think I've been ripped off!! oscarferreira General Mercedes-Benz 5 05-27-2005 04:51 PM
    WAS I RIPPED OFF? endojedi C208/A208 CLK-Class 1 04-25-2005 05:23 PM
    Did I get ripped off? BrendanRehman W126 S,SE,SEC,SEL,SD,SDL Class 3 03-22-2005 10:12 PM
    Am I being ripped off.... Das_Vidas General Mercedes-Benz 2 08-05-2004 01:53 PM
