Speedo, Odo accuracy?? - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 09-30-2008, 04:11 PM Thread Starter
Date registered: Sep 2008
Smile Speedo, Odo accuracy??
On my 1992 190E, I replaced the speedometer-odometer cluster as the odometer was broken. I found a new unit with the correct part #, and installed it. I noticed I was passing all other cars when indicating 65 MPH, so I drove through one of those radar mountae on a trailer at the side of the road that advises "Your speed is", at my indicated speed of 30 MPH, the radar said "35MPH", I tried it several times and always got the same answer.
The question here is: If the speedo is off 18%, does that mean the odometer is off by the same amount? When I checked the mileage, I got 22.5 MPG, the same or similar to what I previously calculated before the odometer broke.
:confused
mrtn is offline
post #2 of 5 (permalink) Old 09-30-2008, 04:26 PM
MB-SV's Avatar
Date registered: Nov 2007
Quoted: 77 Post(s)
That's way off. Maybe tire size (rolling diameter) is way over OEM size.
S.
2013 Mercedes C250 Sport package PLUS steel gray metallic/black
2007 Lexus IS350 Sport package smoky granite mica/gray (+F-Sport, etc.)
2010 Honda Civic GX (CNG) white/tan
MB-SV is offline
post #3 of 5 (permalink) Old 09-30-2008, 07:01 PM
pmark3100's Avatar
Vehicle: 1982 M-B 380SL, 1998 Ford Taurus, 2001 Dodge Ram 2500, Kawasaki ZG1000 Concours
:confused
Get up on the interstate and find a mle marker. Preferably on a long stretch of highway. Pull over right at a mile marker and zero out your trip odometer. Go at least 5 miles and pull over again. Now see how far it says you drove. Mile markers are set out by surveyors and are extremely accurately spaced.
You can also check your speedometer accuracy with a passenger, a calculator, and a stop watch. I like to do this at 60 mph as it just makes it a little more repeatable. Drive at a steady speed, such as 60 mph, from one mile marker to the next. Start the stop watch when you pass the first marker and stop it when you get to the next. Now have your passenger divide 1, by the time it took to travel one mile. Multiply that by 60 to get your miles per minute. Multiply it again by 60 to get the miles per hour. If it took 55 seconds, you would divide 1 by 55 to get 0.018181818181818181818181818. Multiply that by 60 to get 1.090909090909. That's the miles per second. Multiply that by 60 and you get 65.45 mph.
It's really a good idea to check this when you have a lease vehicle. If it's reading high, you pay for say 36,000 miles but only drive 32,000 miles over the life of a lease. That's 2000 miles you paid for but didn't use.
pmark3100 is offline
post #4 of 5 (permalink) Old 09-30-2008, 09:19 PM
Kajtek1's Avatar
Quoted: 1168 Post(s)
Sounds like you've got replacement speedo from a car having different differential.
MB speedometer are very accurate. I am driving with GPS a lot and all of my MB show within 1 mile difference.
My Ford truck shows 65 mph, while GPS reads 60.
Odometer is another story. It is very hard to compare since road markers have lot of errors. I have a second hose in 500 mile distance. Different cars would read between 470 and 503 miles.
Kajtek1 is offline
post #5 of 5 (permalink) Old 10-01-2008, 06:05 PM
pmark3100's Avatar
I'm not sure how the speed sender has ben configured. It may just need a drive gear swap. Most car companies have three or four different gears for different ratios.
On road markers, it depends on which ones you use. The mile markers are set out by surveyor. I think the tolerance is no more than 4 inches per hundred miles. Now, the signs saying a certain number of miles to a certain city are a different matter. I've seen them where you got farther away the closer you got. 50 miles and as I got closer it said 58 miles. These are set where ever is handy. Instead of engineers with surveying equipment, you have a political appointee with a state truck.
    Speedo not working (Speedo Cable Snapped) Monkey Boy W201 190-Class 1 09-01-2008 09:24 AM
    WTB working speedo/odo for 85 300sd glovesave33 For Sale/Wanted/Trade/Giveaway 1 06-01-2008 12:59 PM
    Speedo/odo question Northwinds W124 E,CE,D,TD Class 0 04-02-2008 01:22 PM
    Speedo accuracy of my '93 280E ytr77 W124 E,CE,D,TD Class 2 12-13-2007 01:11 PM
    what is 32 / 13 2 on odo when trying to reset FSS ? Kirill R170 SLK-Class 3 05-02-2006 12:12 PM
