Ignition key - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 09-29-2008, 04:39 PM Thread Starter
Date registered: Jul 2006
Ignition key
I am having a problem starting my 7yr old C220CDi with the ignition fob.It keeps failing to engage the starter motor and I have to keep turning on and off until it eventually starts. The ignition lights mostly come on but are sometimes not operating when I turn the fob. I have been told it is a £500 repair but has anyone a cheaper answer.
dcsheffield is offline
post #2 of 4 (permalink) Old 09-30-2008, 10:28 AM
Date registered: Jul 2008
Before going to change your Ignition Switch or even your starter, replace the Neutral Safety Switch first, most likely located underside of car, driver's side of transmission.
The Neutral Safety Switch also incorporates the Back up Light Switch on some MBZ.
Sometimes, if this is defective, you could still start the car on the Neutral position but eventuall it would not even start anymore in Neutral. I am just sharing you what I went thru. Let me know if I can help you with the part.
Thanks,
349neby
mbnescid is offline
post #3 of 4 (permalink) Old 09-30-2008, 03:06 PM
Kajtek1's Avatar
Vehicle: E320/E250 Bluetec R129 SL500 - $1300 car ........ Ford F350 6.7l
Quoted: 1341 Post(s)
Describe better the " keeps failing to engage the starter motor"
That might be weak battery or wear out ignition switch.
Kajtek1 is offline
post #4 of 4 (permalink) Old 09-30-2008, 10:04 PM
Diesel Benz's Avatar
Quoted: 40 Post(s)
Doesn't this car already have the IR key? If it still starts at least occasionally, it could be a bad starter solenoid/starter motor. I would measure the starter motor solenoid drive voltage when the key is turned. If the solenoid gets drive power, the EIS would be fine. If it only gets power occasionally and the starter motor also runs at the same time, then it sounds like an EIS isssue.
Diesel Benz is offline
'86 190e Ignition key problem- the key won't turn Guest (MBNZ) W201 190-Class 7 04-13-2010 03:35 PM
ignition key mary101 General Mercedes-Benz 4 01-03-2008 06:56 AM
key will not come out of ignition AdamT W140 S-Class 7 08-14-2007 06:11 AM
Ignition Key YOGGI W202 C-Class 2 06-13-2007 01:52 PM
ignition key cylinder mr diesel W123 E,CE,D,CD,TD,TE Class 6 08-20-2004 09:41 PM
