Will Delayed Engine Shut Off Cause Damage? - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 09-29-2008, 11:10 AM Thread Starter
Date registered: Sep 2008
Vehicle: '83 Mercedes 300D Turbo Diesel
Hello folks. I''m the proud new owner of a 1983 300D Turbo Diesel. Currently, the engine continues to run for approximately 10 seconds after I turn it off and remove the key. I am troubleshooting the problem and have found alot of helpful info. My question is, will my engine be damaged in the meantime until I fix the issue? Thanks in advance for any help.
jason300d is offline
post #2 of 2 (permalink) Old 09-29-2008, 11:37 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
Nope.
A diesel engine is shut off by shutting off the fuel supply. No "ignition" system, of course, and nothing electrical is occurring in the process.
On your car, there is a vacuum motor of sorts that accomplishes this.
If it delays, it's probably because there is a problem building up required vacuum in a timely manner. Vacuum leaks, weak vacuum pump, bad "motor," etc. It probably isn't called "motor," but I can't remember the correct term, but it's clearly something that moves in response to vacuum.
Lots of vacuum lines easily disturbed by messing with oil filter.
So, it's just running like it always does until the fuel is cut off.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
    Engine doesn't shut off. yarr Unimog 19 02-27-2011 11:20 PM
    engine shut off countrylanelana W123 E,CE,D,CD,TD,TE Class 4 11-15-2006 10:59 AM
    damage to engine??? gkong W163 M-Class 3 09-19-2003 02:59 PM
    Engine shut off by itself, Help! cabby850 W210 E-Class 0 08-20-2003 12:45 PM
    Engine won't shut off PrinceGeorges W126 S,SE,SEC,SEL,SD,SDL Class 2 07-03-2003 07:53 AM
