Tire type for 18" AMG rims on 2004 CLK 500 - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 09-28-2008, 07:06 PM Thread Starter
Date registered: Sep 2008
I have a 2004 CLK 500 that has the stock 17" AMG wheels. Well I kinda hit the curb the other day and totally messed up the rear wheel and slashed oped both my tires on the passenger side. Had Michelin Pilot all around so it was pretty disheartening.
Anyways I found a great deal and got 4 18" AMG rims with tires for $700 local, miracle if you ask me. Well actually it wasn't because I stayed up until 3 in the morning putting them suckers on to find out that the tires lock the wheels up and the 18" wheels rub against the springs up front.
So I have been scouring through forums for 2 days now trying to find the the right tire that will fit the 18" AMG rim without engaging the ESP or whatever it is that is causing the wheels to lock up. I'm not sure if this is correct but it was stated in another thread here that there is a 3%? allowance in circumference size. Either way, I've used the tire tool and gathered up peoples comments from other boards on the which type is allowable, but which one is best?
I'm hovering between the 255/35 or 265/35. Will the latter work (265/35)? Don't want to end up paying for it and it not being compatible. Also can you go larger? Currently I want the set up to be the 18's in the back and 17's in the front. The front being what came stock the 225/45 17's.
Sorry for the insanely long post but this is bugging me like crazy! I just wanna race daddy!
P.S. Kiddin on the racing but should i stick with Michelin tires? and is it wise to buy them used at like 6 or 7/32 tread?
Thanks in advanced for your help and sorry for the essay and the 20 questions.
Switching from coffee to benadryl - lights out
Rco0123 is offline
post #2 of 5 (permalink) Old 09-29-2008, 01:25 AM Thread Starter
Rco0123 is offline
post #3 of 5 (permalink) Old 09-29-2008, 09:33 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
I would guess that the "lock up" you describe is because your stock lug bolts are too long for the 18" wheels, so they are passing through the hub and engaging hardware behind them, such as the parking brake. If you got lucky you won't have broken or damaged anything.
The other issue is offset, if the 18s are the wrong offset you'll end up having to buy spacers if you really want to use them. Of course you'll then need the proper length lug bolts to accommodate the spacers. If you do have the correct offset, then you can use one of the tire size calculators such as the one at miata.net or 1010tires.com.
As if that were not enough, there are two different ball seat designs and two different lug bolt diameters. (R14 and 14M, R12 and 12M). Your car uses the R14/14M, if the 18s came off an older model (like a W210) then their ball seat would be R12, so you'd need custom lug bolts of R12x14M, available through RADUSAdirect.com. There is also a W209 forum specific to your car, posting in there may yield useful results, and the wheel and tire forum could be useful as well.
Although written for the W210 chassis, this is a thread that may have some useful information about the forest into which you have inadvertently stumbled: http://www.benzworld.org/forums/w210...el-thread.html.
Take care and enjoy the ride,
Check Codes is offline
post #4 of 5 (permalink) Old 09-29-2008, 05:32 PM Thread Starter
Thanks for the help, I really appreciate it. Now I'm wondering if i need to buy tires at all but I will check that website you posted. The tires on them now are 275/35 Continentals, and I'd be saving a good $600 opting out of the michelins.
I was wondering tho if I could keep the 17's up front and have the 18's on the back and keep it like that cause it kinda looks cool i think haha. anyways thanks again!
Rco0123 is offline
post #5 of 5 (permalink) Old 07-13-2010, 12:52 PM
Date registered: Jul 2005
Vehicle: CLK 500
Do you stil have the old 17" rear rim? If so are you interested in selling?
beumpie is offline
    WTT my 18"X8" rims for your W208 CLK 16"X7" OEM rims turboquat For Sale/Wanted/Trade/Giveaway 3 06-30-2008 10:35 PM
    OT: Think about selling me 2006 Clk 500 Cabrio 17" AMG wheels and tires linh R170 SLK-Class 1 03-27-2007 07:53 PM
    18" rims for CLK 500 lockmanmd For Sale/Wanted/Trade/Giveaway 0 09-08-2006 08:30 AM
    FS: 2005 CLK 500 Convertible AMG rims + Bridgestone Blizzak Snow Tires lp10splyr For Sale/Wanted/Trade/Giveaway 9 10-31-2005 07:47 AM
    18" AMG rims tire size please help, Luke undacovabroda The Discount Tire Direct Tire, Wheel, Brake & Suspension 4 03-11-2003 01:56 PM
