Turn signal, high beam, wiper shaft loose - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 09-25-2008, 01:20 PM Thread Starter
Date registered: Sep 2008
I have a 1997 E300. The turn signal lever has gotten loose. I can't tell if something broke inside or it popped out of a socket. It pulls out slightly and the high beams are activated when the lever is pulled up or down for turn signaling. Does anyone have a diagram of how the shaft connects inside?
It is pretty difficult to see how it connects. Does anyone have experience correcting this problem. I would sure like to avoid pulling the whole wheel off if possible.
I have no problem with the cruise control shaft so the collar on the steering column is fine. The problem is where the turn signal lever attaches inside the column.
Thanks for your help.
sbbrian is offline
post #2 of 2 (permalink) Old 09-25-2008, 02:18 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
My guess is that you broke the switch in a particularly aggressive blinker activation.
flyboyike is offline
    97 E320 Combination switch (turn signal,wiper,high beam) alfa01 W210 E-Class 3 05-10-2013 07:56 AM
    W210 - loose turn signal fix durado W210 E-Class 20 11-19-2012 09:55 AM
    High Beam Flash and Right Turn Signal Problems dsepuha W210 E-Class 2 03-25-2011 12:02 AM
    Turn signal wiring harness is loose - any solution? bob98e320 W210 E-Class 0 05-22-2006 05:18 PM
    Help! Need Turn Indicator/Horn/Wiper/Hi-Beam Switch bbrah G-Class 16 07-21-2005 08:10 PM
