Right Rear Water Drain Problems Into Trunk SLK230 2003 - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 09-23-2008, 09:10 PM Thread Starter
Date registered: Sep 2008
Vehicle: 2003 SLK230 USA model, Auto Transmission, Stock, Firemist Red
Quoted: 24 Post(s)
I could not get the drain hose to unclog from top or bottom. So, I pulled it out of the bottom harness area to let it drain into the cavity behind the rear wheel. (The inlet to this hose is the forward right corner of the trunk lid.) After a torrential rainfall, I found that the cavity did not drain properly. I found that I can push my finger up through the about inch wide rubber drain tube and press the bulb several times to get water to flow.
How do I remove the bottom harness to re-install the drain hose? The harness is behind the rear wheel, and hugs the bumper shell outer wall.
How do I get the cavity drain to work consistently? I think I can snake a shop vac hose in there with a reduced size hose, and vacuum out debris, flush, repeat, etc.
Do I need to silicon seal the upper part of the drain to prevent water travel down the PSE wires into the actual trunk area/not the farther right cavity.
Note: I already cleaned up the PSE, and need to solve the source of the water leak and resultant PSE failure.
Thanks in advance.
Thom
Thom
Automatic Transmission
No Alterations/Stock
Southeast, USA
DecoThom is offline
    Right Rear Water Drain Problems Into Trunk SLK230 2003 DecoThom R170 SLK-Class 2 10-29-2013 08:50 PM
    Right Rear Water Drain Problems Into Trunk SLK230 2003 DecoThom R171 SLK-Class 3 09-24-2008 01:08 PM
    Water drain to where? urquell W126 S,SE,SEC,SEL,SD,SDL Class 7 01-17-2008 11:28 AM
    AC water drain plugged AlanMcR W210 E-Class 0 07-03-2004 05:51 PM
    Water drain lines - problems lonny R170 SLK-Class 2 02-18-2004 05:12 PM
