Seafom warning - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 09-21-2008, 01:52 PM Thread Starter
Kajtek1's Avatar
Quoted: 1168 Post(s)
Seafoam warning
Cat glowing red after Seafoam treatment - YotaTech Forums
This is other forum link (hope it is OK to link it here?) where a member got catalytic converter problem after using Seafom.
I used Seafom once in my diesel with no noticeable effects, but this forum had strong recommendations for the stuff. I am trying to check the issue further for more scientific tests, so consider this as consideration at this time.
Seafoam, as with many additives, consists of a solvent in a light oil carrier. Iirc in the case of Seafoam the solvent is naphtha. It works OK for dissolving fuel varnish because that's what it's designed to do. The problem with injecting it into your manifold is that 1) It's not very effective and 2) You end up burning the oil carrier. That's why it smokes so badly. Burning oil from any source isn't good for your engine and it especially isn't good for your catalytic converter if you have one.
Kajtek1 is offline
post #2 of 5 (permalink) Old 09-21-2008, 02:01 PM
Musikmann's Avatar
Quoted: 6 Post(s)
FWIW, the MB branded product #A 000 989 25 45 12 contains naptha and naphtalen. According to the instructions, it is only intended to be mixed with approx. 65 liters of fuel.
Musikmann is offline
post #3 of 5 (permalink) Old 09-23-2008, 12:04 PM
Mercedes Benz of Florida's Avatar
Date registered: Dec 2006
Vehicle: 2000 Mercedes-Benz S500. Sold: 2000 C230K, Sold: 1997 Porsche 944S
Quoted: 26 Post(s)
Send a message via Yahoo to Mercedes Benz of Florida
KAJTEK1;
I read what those guys are saying on the board and I think they are so full
of their own misgivings.
I have used SeaFoam and other products for years, decades, and have never
once had a problem like that or even heard of it.
I think it was a pure coincidence.
Sea Foam is a Fuel Injector Cleaner, not mixed up with the Oil. Unless of course, you do a direct application to the Oil.
Otherwise, it's introduced into the Fuel Tank.
I repeat, never, not once ever had a problem with Sea Foam, Berryman or other High Quality Fuel Injector Cleaner.
Charles
New York City, NY
Richmond County
United States of America
Mercedes Benz of Florida is offline
post #4 of 5 (permalink) Old 09-23-2008, 09:35 PM Thread Starter
Kajtek1's Avatar
The difference might be, that OP used Seafom as an intake cleaner.
Makes logic sense that unburned oil can screw converters. Than it might be all in details.
Kajtek1 is offline
post #5 of 5 (permalink) Old 09-23-2008, 09:54 PM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
There are no liquid solutions to mechanical problems.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
    warning imbackbkm456 Off-Topic 9 01-26-2007 02:56 PM
    Many of you must have seen this warning DieSilberBenz General Mercedes-Benz 11 11-17-2006 10:34 AM
    Warning ThrillKill Off-Topic 10 05-30-2006 08:34 PM
    WARNING WARNING BIG SCAM ON FORUM MBGary W126 S,SE,SEC,SEL,SD,SDL Class 2 03-27-2005 07:02 AM
    Park Brake warning Light and Low fuel warning light Ameet Patel R170 SLK-Class 3 03-21-2001 04:28 PM
