fuel gauge going crazy - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 09-18-2008, 06:13 PM Thread Starter
Date registered: Sep 2008
well hey, i have a 1995 c180 default, nothing added to it, and recently the fuel gauge will suddenly drop to 0 and then go back to 100, and this keeps on repeating. Im not too sure what it is, i think it might be a fuse or something. Comment if you know anything that might help me
bosnarules is offline
post #2 of 5 (permalink) Old 09-18-2008, 06:16 PM
vipercrazy's Avatar
Date registered: Jan 2007
Vehicle: EURO 280CE
Send a message via AIM to vipercrazy
sounds like the sensor has a bad ground or something else in the circuit, like the fuse or gauge, maybe someone has a similar car with this issue. that may be a sign the sensor is on its way out.
for sale: Car Domain 80 EURO 280CE M110.984 english red, white cloth interior 194k
daily driver: 93 toyota MR2, black 5spd non-turbo, may just have to remedy that
mopar: 62 chrysler newport 4DR white 361 V8, 36k miles
vipercrazy is offline
post #3 of 5 (permalink) Old 09-18-2008, 06:18 PM
Musikmann's Avatar
Quoted: 6 Post(s)
You have a W202 C-Class and I would pose your question on that forum. But the 1st place I'd look is at the fuel level sending unit which might be the same thing vipercrazy is calling the sensor. Good Luck.
Musikmann is offline
post #4 of 5 (permalink) Old 09-18-2008, 06:19 PM Thread Starter
by the way, where is the fuse for the guel gauge
post #5 of 5 (permalink) Old 09-18-2008, 06:27 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Don't bother with a fuse, that is not it. Fuses either work...or they don't, period.
MB usually uses similar designs in their sedans, so I"ll bet if you pull the sending unit and clean the contacts (for the variable part of the sender, not the plug where the harness connects) it will be okay. Again, if it is a similar design you can reference the DIY posted in the W210 forum.
Take care and anjoy the ride,
Greg
Check Codes is offline
    Crazy question about fuel gauge edwardgwright W126 S,SE,SEC,SEL,SD,SDL Class 2 06-18-2008 11:19 PM
    CRAZY OIL PRESSURE GAUGE lovemy'93-300CE General Mercedes-Benz 1 03-17-2008 09:43 PM
    Economy gauge driving me crazy B71ZZZ W124 E,CE,D,TD Class 9 02-21-2007 04:40 PM
    THE ECONOMY GAUGE ACTING CRAZY... PimpinBenzo W126 S,SE,SEC,SEL,SD,SDL Class 7 02-20-2007 10:11 AM
    Crazy Fuel gas needle gauge HELP marcelo1967 R170 SLK-Class 6 05-19-2004 05:35 PM
