New member with a vacuum question - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 09-18-2008, 11:29 AM Thread Starter
tlk
Date registered: Sep 2008
Question New member with a vacuum question
1984 300 D Turbo I just inherited the car, it has some vacuum issues.
1) door locks
2) won't turn off with key
when I started testing the pump it seems to work fine 24hg at pump, 22hg at booster. however the pump will sometimes not work at all, and than come back on. I loose the brake booster and other things when when it goes out, but the locks and ignition don't work at all, how much vacuum should there be down the lines for these functions? I'm new to both diesel and MB
tlk is offline
post #2 of 2 (permalink) Old 09-19-2008, 03:42 PM
cheapold280ce's Avatar
Date registered: Sep 2007
Vehicle: 1978 280ce euro found dead on Ebay
Try the search function vacumn cut off should have been discussed before. I am not a diesel owner so can't help there other than to let you know you can manually cut it off from under the hood.
On the point of starting car after 4 years none starting, did you flush the fuel tank and clean the strainer, replace the fuel filters, toss the oil diesel?
Also copy your post to here:
http://www.benzworld.org/forums/w123-e-ce-d-cd-td/
cheapold280ce is offline
    Member question Rickysa W126 S,SE,SEC,SEL,SD,SDL Class 2 07-17-2008 04:45 PM
    New Member Question Steelbirds W116 S, SE, SEL, SD Class 1 04-06-2008 06:17 AM
    Dwarf + member + vacuum cleaner = ? Jakarta Expat Off-Topic 1 11-09-2007 02:58 PM
    New Member with a question. 99Benz 300E W123 E,CE,D,CD,TD,TE Class 2 06-10-2005 06:23 PM
    New member question... Guest (MBNZ) W124 E,CE,D,TD Class 1 03-22-2002 03:39 PM
