Tire pressure monitors? - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 09-16-2008, 07:31 AM Thread Starter
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 374 Post(s)
I have seen reference on these forums to M-B models that have been fitted with Tire Pressure monitors.
I do not have this feature. Does anyone know how they work?
keyhole is offline
post #2 of 7 (permalink) Old 09-16-2008, 08:04 AM
Diesel Benz's Avatar
Quoted: 35 Post(s)
Cars like your CLK from 2004 would use the Beru tyre pressure monitor system. A lot of info available at the Beru web site.
Basically each tyre has a sensor inside the wheel, attached to the valve. The sensor transmits pressure and temperature info, received by antennas/receivers at the car side which pass the info to the tyre pressure monitor control unit and that again via the CAN bus to the cluster etc.
Information for Download
Diesel Benz is offline
post #3 of 7 (permalink) Old 09-16-2008, 08:25 AM Thread Starter
keyhole's Avatar
Quoted: 374 Post(s)
Thanks for that.
What with wheel electronics, an ECU, two antennae and four LF satellite triggers, I think that I will carry on just kicking the tires now and again....
keyhole is offline
post #4 of 7 (permalink) Old 09-16-2008, 09:40 AM
Premium Member
roncor's Avatar
Date registered: Jan 2005
Vehicle: '91 420 SEL, '80 240D, '87 560 SL, '93 190E Sportline, '70 300 SEL 6.3
Quoted: 40 Post(s)
Premium Member
Here's a cheap alternative - valve stem caps that change color when pressure drops. At $19.95 it will keep you from kicking your poor tires!
AutoSport Catalog - Tire Safety Monitors 800-953-0814
roncor is offline
post #5 of 7 (permalink) Old 09-16-2008, 09:58 AM
MB-SV's Avatar
Date registered: Nov 2007
Quoted: 77 Post(s)
Good information. Thanks.
S.
2013 Mercedes C250 Sport package PLUS steel gray metallic/black
2007 Lexus IS350 Sport package smoky granite mica/gray (+F-Sport, etc.)
2010 Honda Civic GX (CNG) white/tan
MB-SV is offline
post #6 of 7 (permalink) Old 09-16-2008, 10:13 AM
Kajtek1's Avatar
Quoted: 1166 Post(s)
The plastic gizmo above is basically garbage.
If you want to add monitoring system Pressure Pro is the best on the market. I bought it for my RV and occasionally use it on cars. It is really nice to check the pressure at 75 mph and from reviews here I believe Pressure Pro is superior to the system MB uses.
PP sensors with about 1" diameter screw on the tire valves and activating and calibrating them-self at that moment. They send signal all the time every 5 minutes with battery life of about 5 years. In RV when the receiver is plug on all the time, you will know your pressure dropped while at sleep at 3 AM
The only problem on cars wheels I found was, that the rubber valve steam flex and the sensor rubs the rim. I solved it by adding rubber tape on the rim in this area. With 1 oz weight some recommend wheel rebalacing, but I drove 80-90 mph on regular basis and no vibrations.
Kajtek1 is online now
post #7 of 7 (permalink) Old 09-16-2008, 10:54 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
You can thank Ford Explorers and Firestone tires for the requirement these systems be fitted on all new cars.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
    Winter Rims and Tire Pressure Monitors Ted in Toronto W204 C-Class 3 09-18-2007 07:11 PM
    TIRE PRESSURE k85o91 C208/A208 CLK-Class 2 03-22-2006 02:09 PM
    taking down tire pressure for 4x4 ing. could you do that on a low profile tire? blau The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 01-06-2006 02:49 PM
    Luke - Tire Pressure Monitors on ASA ST3 Carl_in_DC The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 10-20-2005 11:06 AM
    tire pressure sjtymko G-Class 6 01-20-2003 12:44 AM
