'82 240d refuse to engage - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 09-16-2008, 04:22 AM Thread Starter
dyonsl's Avatar
Date registered: Sep 2008
Vehicle: 1982 W123 240D LHD ex Germany 4 spd manual transmission
Hie guys
Im having a prob with my new manual transmission '82 240D, sometimes it refuses to engage into gears. Any help
Also there is a switch which I understand to be an idling switch , just wanted to know when to use it.
Its consuming about a litre per 10km, is this okay, does the idling switch have anything to do with idling and how do I reduce or decrease the idling speed from the engine
thanx
dyonsl is offline
post #2 of 4 (permalink) Old 09-16-2008, 07:14 AM
Date registered: Jan 2004
Quoted: 30 Post(s)
Idling knob - gently press on the accelerator pedal to relieve the tension on the idling knob and turn it left or right to reduce or increase the idle speed. I have found that if the car is running right, that I can leave it at the lowest idle and never even have to touch that knob.
Transmission - there are some bushings in the linkage that can deteriorate and or completely fall out that could cause the shifting issue you are having. They are very cheap and not a real hard DIY job.
Len
sokoloff is offline
post #3 of 4 (permalink) Old 09-16-2008, 07:28 AM Thread Starter
dyonsl's Avatar
Thanx Len, I would like to agree on the bushings issue because I hit a few potholes some days back.
My idling sounds good so Im gonna leave it like that.
If I may ask something else, does MB require rear wheel alignment as well or just front wheel alignment
dyonsl is offline
post #4 of 4 (permalink) Old 09-17-2008, 06:24 AM
Quoted: 30 Post(s)
If you want, send me a note offline and I can send you a drawing of the bushings I'm talking about. Rear wheel alignment can be checked, but not adjusted unless you replace mounts, bushings, etc.
Len
len@sokoloff.com
sokoloff is offline
    23 Senators refuse to disclose home mortgage details......... Jakarta Expat Off-Topic 4 06-24-2008 11:34 AM
    Caught speeding on camera, police officers refuse to pay tickets Jakarta Expat Off-Topic 6 03-10-2008 06:05 PM
    We reserve the right to refuse service to anyone......... Jakarta Expat Off-Topic 0 01-08-2008 06:32 AM
    Liftgate refuse to OPEN drkchan W164 M-Class 8 03-24-2006 07:54 PM
    An SLK offer I can't refuse? sjones R171 SLK-Class 11 07-27-2005 02:44 PM
