>>300SL Auxillery fans/switch 1990 300SL - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 09-15-2008, 05:30 PM Thread Starter
Date registered: Sep 2008
So my car gets hot and has had issues since I got it. (1990 300sl). The auxillery fans stopped working and a switch was replaced but they keep stop working. Does anyone know where this switch is and is there a way to bypass the fant switch sensor with a direct on off switch-tap into the wire and send either current or ground to activate the relay...any help is appreciated please post here OR get back at me at timeforsound at Yahoo dot com.
zintcat is offline
post #2 of 3 (permalink) Old 04-10-2012, 05:38 PM
Katila66's Avatar
Date registered: Apr 2012
Vehicle: 1990 300SL
Smile You can easily bypass this sensor
I have the same issue on my 300SL. When I killed my entire cooling system with the wrong antifreeze, I found that my fans were not engaging either. I went through a lot of searching to find what I thought was the correct sensor/switch and am still unsure I got the right one. My Merc spec says it may not be the sensor at all but could be anything along that wiring, even with the working bypass.
It's easy enough to bypass the sensor as I did so that fans stay on whenever the key is on but that's not really very good for the fans to be on all the time. I did discover that without the bypass, the fans work properly as long as the cooling/heating is on. So you can set the temp and just leave it on Automatic setting all the time and it should kick the fans on and off. (The A/C will not work if the sensor is bypassed) Just unplug the wires from the sensor and connect the bypass (a wire with an alligator clip at each end) to each of the wires and it will cause the fans to work with the key. You can wire the bypass to a kill switch inside the car if you want, but for me it's not worth it. I'll just leave the climate control on auto.
Katila66 is offline
post #3 of 3 (permalink) Old 04-13-2012, 04:56 AM
eric242340's Avatar
Quoted: 283 Post(s)
Welcome to Benzworld
eric242340 is offline
    1990 300sl ShouldI? R129 SL-Class 7 03-08-2007 09:52 AM
    1990 300SL amplifier location??? rcltrh R129 SL-Class 5 05-28-2006 12:22 AM
    1990 300SL vs 500SL DougiD R129 SL-Class 5 06-07-2005 03:28 AM
    1990 300SL Burt R129 SL-Class 0 03-21-2004 06:27 PM
