2004 SLK 230 problem: BAS/ESP light on; shifter stuck in park - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 09-04-2008, 10:05 AM Thread Starter
ruslan@global.t-bird.edu's Avatar
Date registered: Sep 2008
Vehicle: 2004 SLK230
Greetings!
I have a 2004 SLK 230, 40K miles. While driving, a BAS/ESP light came on. Next morning, couldn't shift out of park. Brake lights don't work when the brake pedal is depressed. Car is undriveable, stuck in the garage.
MB shop told me to have it towed because it could be "a variety of serious problems".
I received some sensible advice here to pull and reinstall a stop lamp switch as an easy remedy. Problem is, I don't have a service manual, and don't have any schematics for removing under-dash covers and getting to the switch. Tried to look for the switch this morning, and failed miserably. Plastic covers go all the way to the floor, it seems.
To your knowledge, are all SLK stop light switches similar? There was a stop lamp switch schematic in the forum, and I wonder if the adjustment procedure is the same for all SLKs (unplug S9 connector, press S9b catch, pull pin S9a all the way out, reinstall). Should I get a new part, or clean and reinstall the old one?
Also, couldn't find any fuses for the traction system in the fuse box. Could it be a blown fuse, and if so, which fuse do I need to inspect?
Your advice is greatly appreciated. Certainly don't want to have this towed.
Thanks, and best regards,
Russ
ruslan@global.t-bird.edu is offline
post #2 of 5 (permalink) Old 09-04-2008, 01:21 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Hi, Russ.
The switch is very cheap, even at the dealer only about $20, and they fail more often than they should. So I'd say don't try adjusting, etc., just replace the thing. That should resolve both issues.
Take care and enjoy the ride,
Greg
Check Codes is offline
post #3 of 5 (permalink) Old 09-05-2008, 06:46 AM
Andrzejek's Avatar
Date registered: Jul 2004
Vehicle: 00 C-230, 04 C-240
The brake switch is located close to the top of the brake pedal. You will have to remove a small plastic access cover to get to it. Once you find the switch, depress the brake pedal & notice if the switch plunder moves. If it does not, try to move the plunger by hand to free it. They get stuck in the off position. This has happened to me a few times, so I keep the plastic access window off so I can free the switch if needed.
You can also attempt to free the jammed switch by "snapping" the brake pedal -- depressing it and than sliding your foot off to one side.
One other thing to note is that the transmission can be switched into gear by inserting a pen into a small access hole located right next to the shifter. This emergency procedure is explained in the Owner's manual.
Good luck.
Andrzejek is offline
post #4 of 5 (permalink) Old 10-05-2016, 09:22 AM
Date registered: Oct 2016
Just wanted to say that this post was quite the lifesaver!! Only had my 2004 SE SLK for a couple weeks and was on vacation. Went to get back in my car and could not get it out of park, then noticed the BAS light on. Thank God for the iphone & you folks!!
Becky
Becky59 is offline
post #5 of 5 (permalink) Old 10-06-2016, 04:27 PM
galaxys's Avatar
Date registered: Nov 2008
Vehicle: 2011 SLK300 Plutonium Silver (2002 SLK230 Sold)
Becky
Glad you fixed it. I had the same issue a few years ago on my SLK 230 and replaced that brake switch! Cheers
galaxys is offline
    bas esp and being stuck in park solved! SinesurfR W202 C-Class 1 07-07-2008 05:43 PM
    Slk ESP/BAS, E-Brake Light issues HELP!!! MrRed R170 SLK-Class 6 02-16-2008 03:42 AM
    Stuck in Park - BAS/ESP light on splewis57 W163 M-Class 0 04-04-2007 06:57 PM
    Problem with BAS/ESP problem light. WHat to do? J1A1H C208/A208 CLK-Class 5 08-14-2005 02:02 AM
    ESP/BAS light on and truck won't shift out of park Andy-Montreal W163 M-Class 12 02-15-2003 09:44 AM
