Transmission Issues - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 09-03-2008, 04:25 PM Thread Starter
Ajimoli's Avatar
Date registered: Sep 2008
Vehicle: 1987 420 SEL
Transmission Issues
Hi to everyone. I'm new to the forum but have had my Benz for 4 years. It's a 1987 420 SEL with 219,000 miles. I really love the car and have slowly been tinkering with it to keep it looking and running well.
The transmission seemed to be shifting irratically so I recently took the car to my local mechanic - whom I've always had alot of confidence in. They replaced a number of hoses on the transmission that were leaking and replaced some kind of valve body that was mounted outside the transmission. They also completely drained the fluid and relaced it with new. All of this cost me about $ 450.00. A couple of weeks later while driving the car on the highway, the transmission would - for no reason - drop down by one or even two gears and shoot the engine RPM's up really high. I quickly slipped the shifter into neutral and the RPM dropped down. I would wait about 5 to 7 seconds and then slip it back into drive and everything would be OK. After it did this 3 or 4 times, I took it back to my mechanic and they seemd awfully quick to tell me that the transmission was shot and I would need a new one. I brought the car home (about a 10 minute drive) and it ran perfectly - with no issues. I drove it again today for about 15 minutes and it did the shifting down thing 3 times. Once I shift the car into neutral and back into drive everything runs perfect.
So here is my quandry. Do you guys really think the transmission needs to be completely replaced or is there something else, that might costs less money to repair, that might be wrong. It doesn't make sense to me that the car can run so well between these "events" if the transmission was toast.
If anyone else has experienced similar problems and might be able to shed some light on the subject - I would surely appreciate it.
I belong to a couple of other forums for the hobbies that I have and really believe in the idea of talking with fellow owners such as yourselves.
Thanks, in advance, for any help you can give me.
Paul Roza
Waxhaw, NC
Ajimoli is offline
    Transmission issues (1990 300E, 3.0L, 722.5 transmission) Eric@StarSuzuki W124 E,CE,D,TD Class 5 04-13-2011 07:29 PM
    Transmission Issues VTach W126 S,SE,SEC,SEL,SD,SDL Class 14 10-19-2007 07:57 PM
    HELP TRANSMISSION ISSUES bcomras W163 M-Class 8 08-10-2007 06:37 PM
    Transmission issues Cyberbach W123 E,CE,D,CD,TD,TE Class 23 05-07-2007 07:12 AM
    Transmission Issues danwatt W126 S,SE,SEC,SEL,SD,SDL Class 1 03-04-2006 12:47 PM
