Q: Brake Pads And Caliper HELP!! - Page 2 - Mercedes-Benz Forum
post #11 of 16 (permalink) Old 09-05-2008, 10:31 PM
Diesel Benz's Avatar
Quoted: 37 Post(s)
Originally Posted by sleepy_b View Post
bro, with sbc brakes they are always testing the system. for the future these cars have a lot of odd technologies so check with you dealer before you tear stuff apart. i don't mean to sound like i am ripping on you but it could save a lot of money if you just ask them first. believe me, I make a lot of money off of do it yourselfers.
And it isn't about money only, one can save fingers too. If the SBC system gets activated while one is working with the pads, the system brings pads close to discs and if you happen to have fingers in-between:
It still is not clear to me where the fluid leak was from, it could have been from the above operation when brake cylinders came out far enough to let fluid come out. In that case the whole system would need to be bled (at least).
Diesel Benz is offline
post #12 of 16 (permalink) Old 09-06-2008, 09:12 AM Thread Starter
Date registered: Sep 2008
yeah what i think is it needs to be bleded but benz is obviously so dumb to realize that but what ever going in on MONDAY thanks guys !
GQSL500 is offline
post #13 of 16 (permalink) Old 09-06-2008, 09:00 PM
Date registered: Aug 2008
just out of curiousity. when you say that the fluid leaked out what bolts did you remove on the calipers. not the large ressesed torx bolts that can be seen on the outside of the caliper was it. that would explain the fluid leak. if the person that told you that was the service advisor wouldnt form an opinion of the techs off of them. If they have seen that complaint before and that is what the tech said was wrong then they assume that is the problem all the time. Not all advisors are like that but a lot are so don't start flaming me for that comment. I promise I am not trying to stereotype.
sleepy_b is offline
post #14 of 16 (permalink) Old 09-07-2008, 04:37 PM Thread Starter
haha yes those would be the bolts , and i already refilled the fluid still no help i just hear my sbc module pumping everytime, ill tell them tomorrow.
GQSL500 is offline
post #15 of 16 (permalink) Old 09-07-2008, 09:48 PM
Quoted: 37 Post(s)
Refilling is not enough when brake lines/SBC pump has got air inside. Hopefully all the workshop needs to do is bleed the system.
post #16 of 16 (permalink) Old 09-07-2008, 11:30 PM Thread Starter
crossing my fingers
GQSL500 is offline
    Anyone replace their brake pads with aftermarket pads? I've seen some ads stating less brake dust. C Brian C208/A208 CLK-Class 20 06-14-2012 09:34 PM
    Q: Brake Pads And Caliper HELP!! GQSL500 R230 SL-Class 6 09-18-2008 08:37 AM
    Removing pads from a fixed caliper christoj879 W126 S,SE,SEC,SEL,SD,SDL Class 1 06-21-2008 07:37 PM
    brake pad wear Q, new front pads, still on, left caliper had no wire/sensors,rightDid brax W123 E,CE,D,CD,TD,TE Class 4 04-15-2008 03:27 AM
    Official Now: My original rear OEM brake pads lasted 74, 500 miles. I bought new OEM pads, a brake AC_ML W163 M-Class 2 02-07-2004 04:25 PM
