Intermittent A/C problems with my 1998 C230 - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 08-30-2008, 10:49 AM Thread Starter
Date registered: Aug 2008
Vehicle: 1998 C230
Question Intermittent A/C problems with my 1998 C230
Fault: Air conditioner runs for approximately 3 minuets then the compressor shuts down. I ran the N22 diagnostics and error codes 419 and 416 appeared. I personally replaced the A/C clutch and the recirculation pump. This appeared to have corrected the problem. However, three weeks later I’m faced with the same issue. I ran the same diagnostics and no error codes were reported. I replaced the battery since it was the original battery. I, also, replaced the radiator cap for the same reason. I’m not sure if the N22 climate control computer is brain dead or the electrical connections to the unit have corrosion, therefore giving me intermittent faults. I tried running the heater to burn off any condensation that may have accumulated on the evaporator sensor to see if that could be causing my problem. At first it seamed to work, but after several days I was back to the same problem. I repeated the heater routine with no luck and the N22 still reports no errors. Using the N22, I tried reading the actual values from all acquisition devices and several values don’t correlate to the diagnostic tables in the manual. Below are actual values:
01 In care temperature sensor -- 92 degrees symbol F
02 Outside temperature indicator-- 87 degrees symbol F
03 Heater Core temperature sensor-- 86 degrees symbol F
04 Not used
05 Evaporator temperature sensor-- only the number 144 appears
06 ECT sensor: only the number 138 appears
07 Refrigerant pressure: 07 degree symbol 4 or 7.4 bar
08 Refrigerant temperature sensor; 95 degree symbol 4 or 95 deg F
09 Not used, however 35 degree symbol F appears
10 Blower control voltage: only the number 400 appears
20 Control current for auxiliary: 35 degree symbol 0 appears
21 Engine speed: 070
22 Vehicle speed: 000
23 Battery voltage: 000
24 Value 24 Not listed in diagnostic table, but gives value of 13.6
40 Software status: 02
41 Software status: 3
42 Version code 1: 18
43 Version code2: 6-c
50 Not used: value shown is 84 degree symbol F
51 Not used: value shown is 72 degree symbol F
52 Not used: value shown is 50 degree symbol F
54 On –Off A/C compressor: OFF
Can anyone tell me if my version code is correct, because some of the values shown don’t agree with the diagnostic table?
radavi4 is offline
    2006 C230 with intermittent radio failure on startup, am I the ONLY ONE !!! rhody527 Audio & Telematics Forum 6 01-20-2012 11:48 PM
    1998 c230 with cup holder problems dennis_larson W202 C-Class 15 07-16-2009 05:46 PM
    2000 c230 a/c intermittent HELP!!! wolfshaus W202 C-Class 0 08-12-2008 06:01 PM
    1998 C230 two unrelated problems Izzum88 W202 C-Class 1 12-16-2004 07:38 AM
    Intermittent Nav Problems ccweems W163 M-Class 3 08-16-2003 10:33 AM
