R129 93 500SL Hard Top - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 08-28-2008, 01:28 PM Thread Starter
Date registered: Aug 2008
Vehicle: 1993 500SL
I have a 93 500SL. Did not drive for a couple months, so, being the newbie that I am, charged the battery without disconnecting and blew out the instrument cluster. I sent it to the place in Canada, (they pick it up in N. Dakota). All is fine there.
BUT--I also reported to the dealer that the hard top will not come off. They responded with the following:
"Short test. Control unit will not read out information. Check all fuses, found one main 30 amp cracked, replace. Check the operation of the top control unit; windows, roll bar, and close fiunction work but no opening. Still cannot read out the information. Follow diagnostic chart and test. All powers and ground ok. The control unit is faulty. See PNA. Replace control unit and sync windows. recheck operation. The top works now but the windows do not go down automatically with the top operation. They do work when you express down with the window switch. Both of these functions are through the top control unit. The only thing Mark B. and I can think of is the open switch in the window motors are stuck closed. With would allow the top to work with then up. Customer just needs to open the windows before opening and closing top."
They show parts replaced as:
1 each 000-545-20-34 Fuse $4.28
1 each 129-820-00-97 Control Unit $1815.00
So, I drive it home 15 miles (like a dummy, I did not verify top operation at dealer) and when I tried it in the garage, still not working.
So, I brought it back--this is their new line:
"Customer says top does not work at all. Check hard and soft top operation, everything is working correctly except the right rear latch does not latch down. Needs RR latch assy. P/N 129-800-12-79 - $605.00 + 2 hours labor. Per RK we can install the latch at no charge to clients and discount the latch assy. Client declined repairs at this time.
So, a couple things come to mind:
1. Was it necessary to even replace the control unit?
2. Did they actually perform a viable test and have it work when siging off the first repair?
3. What could be the problem with the windows after the fix?
4. Should I have them do the last fix suggested?
Why would it not work after a 15 mile trip? I am EXTREMELY sceptical of their honesty and of their competence. The hard top will only appear to "suck down" a bit when trying to remove it with the center console switch.
I appreciate any help. If you would prefer, I can post this instead, but, as earlier stated, I cannot see how to do it.
Thank you very much.
JAYSONBENZ is offline
post #2 of 3 (permalink) Old 06-21-2011, 04:16 PM
Date registered: Apr 2009
Vehicle: sl 300/24 1990mod
I see this is an old post, and i cant find any answers to this link.
But i have the exact same problem with my car as you describe.
The windows are working fine, but the only thing that happens when i use the center button (red one) is that i lock down. It pull down the hard and soft top, and when they are fitted it just sucking it down a cm or so. The same with the deck over soft top.
So since this is and old thread, what did you do, and did you fix it?
Norwaysl300/24 is offline
post #3 of 3 (permalink) Old 05-22-2012, 09:46 PM
Deepsand4wheelin's Avatar
Date registered: May 2009
Vehicle: 93 R129 Glacier White,2000 Jeep Wrangler,2001 Harley Heritage,2005 Toyota Camry
sounds like you might not have known much about these guys from the start , you can get help with that in this forum . Otherwise find your closest MB dealer for service.
NEVER BUY WHAT YOU CAN'T SELL
Deepsand4wheelin is offline
    DIY Hardtop Hoist (R129 Hard top with one man & one hand operate) msmith66 R129 SL-Class 50 03-15-2009 05:37 PM
    WTB (LONG SHOT) - SL500 (R129) GRILLE, HARD TOP STAND aboynton For Sale/Wanted/Trade/Giveaway 4 12-04-2008 12:13 PM
    For Sale R129 Hard Top karlwood For Sale/Wanted/Trade/Giveaway 0 05-13-2008 10:37 PM
    WTB Panoramic hard top for SL500 - R129 - Bay Area Ryan G For Sale/Wanted/Trade/Giveaway 0 04-12-2008 03:35 PM
    82 500sl hard top problems Guest (MBNZ) R/C107 SL/SLC Class 1 08-02-2002 12:32 AM
