Hello 722.631 722.6 trans problem - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 08-27-2008, 08:21 PM Thread Starter
Date registered: Aug 2008
Hello i was wondering if there is anyone out there that could help with some good info.Ive got a 98 c43 amg with trans problems,big surprise LOL.Im getting the complete run around here in Orlando by the dealer.And im looking to find some real advice.I dont even know where to start.About 2 weeks ago the trany lost 4th and 5th gear.Its pretty much stuck in 3rd gear limp mode hydraulic.I changed the conductor plate hoping it would fix it and it did need to be replaced due to the 3rd rpm picker upper being cracked.But in doing so i relized there was radiator fluid in the trans.My question is if i changed the radiator and flushed the trany like 3 times with new fluid would there be a way of saving the trans?If you first start it,it will still get down with the power in the first three gears but then just tacks out when the shift goes from 3rd to the 4th gear.The one question i got is if i could flush it to get it all out could i use some cheaper trans fluid just for the flushing only and then use the 722.6 fluid on the last refill?Only after putting in a new radiator.Thanks Trevor
mb98c43amg is offline
    Automatic transmissions, 722.3 vs. 722.5, what are the differences? Eric@StarSuzuki W124 E,CE,D,TD Class 2 04-06-2013 07:02 AM
    DIY Mercedes 722.3 722.4 722.5 Transmission K1 Piston Spring Repair Kit Install HATTENATOR W201 190-Class 83 10-27-2010 11:19 AM
    difference between 722.350 and 722.323 trans lander91 W126 S,SE,SEC,SEL,SD,SDL Class 7 04-11-2010 04:11 PM
    MB Transmission 722.6 & 722.9 oil change from MB Service Dawson AMG W210 E50 AMG, E55 AMG 23 11-24-2009 09:52 PM
    is transmission problem?! 722.4 or 722.1 ?! kiwiya2001 W123 E,CE,D,CD,TD,TE Class 13 10-07-2005 10:52 PM
