V6 3.5 L Gasoline engine - Coarse and rough at high rpm? - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 08-22-2008, 01:57 PM Thread Starter
Date registered: Sep 2007
Vehicle: '08 S500 w/ AMG Sport Package
Question V6 3.5 L Gasoline engine - Coarse and rough at high rpm?
I read on more than one occasion that the Benz's V6 3.5 engine, also named M272 and used on models with 350 suffix, does not produce particularly pleasant sound at a high rpm range. Plus it also said it's not the smoothest and most refined V6 engine, the reason being that V6 engines prefer 60' vee angle, but the Benz's 3.5 has engine blocks with a 90° vee angle.
Is this true? Do you experience anything similar?
I ask this because I'm interested in an upcoming GLK 350, but if the above holds true, then I'll have to look elsewhere, such as Q5, which happens to have an award winning 2.0 Turbo engine.
Unbiased answer much appreciated!
autoque is offline
post #2 of 5 (permalink) Old 08-22-2008, 02:40 PM
MB-SV's Avatar
Date registered: Nov 2007
Quoted: 77 Post(s)
Not true, because Mercedes uses a single balance shaft to cancel primarily the vibrations that result from the configuration mentioned. The Mercedes 3.5L is smoother than an Infiniti large V6 or any 4 banger.
IMHO, a flat 6 Porsche engine is smoother and sweeter than any V6 that I've driven.
Good question, because I'm picky about things like that too. And that's why I refuse to own anymore 4 cylinder cars.
SIMPLE ANSWER - No the 3.5L V6 is not coarse and rough at high rpm's.
S.
2013 Mercedes C250 Sport package PLUS steel gray metallic/black
2007 Lexus IS350 Sport package smoky granite mica/gray (+F-Sport, etc.)
2010 Honda Civic GX (CNG) white/tan
MB-SV is offline
post #3 of 5 (permalink) Old 08-22-2008, 11:04 PM
n5160u's Avatar
Date registered: Apr 2004
Vehicle: 2000 Designo SLK-05 C230WK-05 E320CDi-2010 GLK 350
You are quite correct about 60 degree V engines. A balance shaft will MASK the unbalanced operation of the odd firing angle but it will never eliminate it or its long term wear effects. That and the simple fact that nothing comes for free (the balance shaft will use between 3~6 hp in operation) and you see that a V6 will never surpass an inline 6 of similar size and tune.
You need to drive an older E300 or any BMW with an inline six to see what I am talking about. Just go do it now, and then consider all the advice given here later after you have a some real experence to consider what you see here.
Potato Chip, custom canuter valve, low-friction muffler bearings, synthetic turn signal fluid, Hi-Definition Progressive Scan Wiper Blades.
Law-makers are supposed to regulate in the interest of the public as opposed to regulating in the interest of the regulated party.
If it says Pratt and Whitney on the outside it better say Martin Baker on the inside.
n5160u is offline
post #4 of 5 (permalink) Old 08-23-2008, 09:29 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
"Rough" is not used in conjunction with Mercedes these days, although it certainly was in the '70s-'80s before it finally caught up with BMW and made something besides truck engines.
For all the reasons there are no longer straight-8s, the straight 6 is basically an anachronism these, days, only really BMW retaining them for market differentiation purposes. They're certainly a hazard in front collisions in comparison. And, there's no such thing as an older Mercedes that's better than the newer ones.
But, no V6 is ever going to sound particularly cool out the exhaust pipes.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #5 of 5 (permalink) Old 08-25-2008, 10:04 AM
MB-SV's Avatar
Quoted: 77 Post(s)
Unlikely that the wear associated with 60degree V6 configuration is significant. More like the hope of longer engine life by changing synthetic oil every 5K miles instead of 10K or 13K miles as recommended by MB.
Look at all the poorly balanced 4-cylinder Japanese engines running 150K+ miles.
S.
MB-SV is offline
    High RPM engine cuts out Dans94e420 W124 E,CE,D,TD Class 6 05-12-2007 01:01 PM
    High engine idle RPM goodguy2 Vintage Mercedes-Benz 1 10-19-2006 04:48 PM
    Rough Idle and engine hesitation/misfiring at high rpm slingerone2002 W124 E,CE,D,TD Class 5 11-18-2005 07:32 AM
    finally solved engine miss @ high rpm brian/ont W163 M-Class 0 05-10-2004 05:17 PM
    engine misfire at high rpm and load brian/ont W163 M-Class 4 01-10-2004 02:52 PM
