81 300TD Vacuum pump, which one? - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 08-19-2008, 12:02 PM Thread Starter
BPW
Date registered: Aug 2008
The last 6 numbers of my VIN is 003152. I need to have the vacuum pump rebuilt as my doors won't lock, the climate control is stuck at HEAT and the car runs on when shut off when it's hot.
Which rebuild kit should I use? Suggestions please.
I think that I have attached a photo of the pump on my engine.
BTW, where is the engine number?
Thanks,
Brian
BPW is offline
post #2 of 9 (permalink) Old 08-19-2008, 12:12 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 696 Post(s)
My advice is to replace the pump for $179: Mercedes 617 Engine Parts. There are two rebuild kits (valves and rocker arm), you'll need to determine the problem if you want to go that route.
GeeS is offline
post #3 of 9 (permalink) Old 08-19-2008, 02:34 PM
Kajtek1's Avatar
Quoted: 1195 Post(s)
Before you replace the pump, make sure it is bad. Very common on those cars are disconnected vacuum lines, especially in the oil filter area. Pumps last long time.
Than from what I recall those are digraph (?) pumps. Digraph alone shouldn't be too expensive? If you can buy it sepratelly that is.
Kajtek1 is offline
post #4 of 9 (permalink) Old 08-19-2008, 05:34 PM Thread Starter
BPW
Hi German Star,
If I replace the pump, is it a simple job of removing the vacuum hose from the pump and remove the old pump and replacing it with the new?
Kajtek1: Checked all of the lines first, very little vacuum before the power brake accumulator.
Thanks,
Brian
BPW is offline
post #5 of 9 (permalink) Old 08-19-2008, 05:40 PM
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 696 Post(s)
No, it's the new style pump. If it were the old diaphragm style pump, I would have recommended the repair kit.
GeeS is offline
post #6 of 9 (permalink) Old 08-19-2008, 05:40 PM
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 696 Post(s)
Originally Posted by BPW View Post
Hi German Star,
Thanks,
Brian
Yes, it isn't difficult, the pump is right up front and accessible.
GeeS is offline
post #7 of 9 (permalink) Old 08-19-2008, 09:37 PM
Kajtek1's Avatar
Hi German Star,
Thanks,
Brian
Bad pump would affect your brake booster. Do you have problems stopping the car?
Kajtek1 is offline
post #8 of 9 (permalink) Old 08-20-2008, 09:34 AM Thread Starter
BPW
Nope, stops quickly and the pedal is firm.
Brian
BPW is offline
post #9 of 9 (permalink) Old 01-14-2009, 04:32 AM
Date registered: Dec 2008
Sometimes the two small tubes that feed vacuum to the lines become clogged. When running, disconnect the tubes and put your fingers over them (or a vacuum gauge.) If you do not feel suction, you may have a clog too (since the brakes work OK.)
On one car, I even had to drill out the hole to free a jam. Problem free ever since!
w123benzman is offline
    Vacuum help: Hatch lock on 83 300td amccune W123 E,CE,D,CD,TD,TE Class 0 08-08-2008 01:43 PM
    vacuum line?s 79 300td actthechange W123 E,CE,D,CD,TD,TE Class 0 06-02-2008 02:17 PM
    Low vacuum on booster line. Do I need to rebuild vacuum pump? dentate gyrus W123 E,CE,D,CD,TD,TE Class 6 04-18-2007 07:58 PM
    1985 300TD - Need a vacuum diagram Trevor Harris W123 E,CE,D,CD,TD,TE Class 4 04-10-2007 11:55 AM
    Vacuum pump rebuild kit or whole new pump 81bobby300D W123 E,CE,D,CD,TD,TE Class 1 03-31-2007 11:51 AM
