2000 ckl320 won't start after 15 minute drive - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 08-17-2008, 01:52 PM Thread Starter
Date registered: Aug 2008
Unhappy 2000 ckl320 won't start after 15 minute drive
My 2000 clk320, starts fine every morning and every night, but when I drive for 15-20 minutes during the day and I stop at a store (80-90 degree normal outside temp) the car just cranks when I get back in 10 minutes later. After 3-5 attemps at around 10 seconds each it will then start and run without a problem. The car did stop once while caught in bumper to bumper traffic and re-started about 5 minutes later. The temp guage on the dashboard reads about 90- 100 degrees. This is a recent problem which started about 4 weeks ago.
mercedave is offline
post #2 of 3 (permalink) Old 08-17-2008, 03:47 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Hi, Dave, welcome to the forum. The W208 forum is the home one for your car, the general forum can be "too general". When you have a minute click the usercp link and update our profile to include your vehicle and location.
In this case that sounds EXACTLY like a CPS, it's a fairly common problem.
There is a DIY in the W210 forum (E class) that is exactly the same for your car, so you can use that to DIY. Depending on the part (there are two different ones potentially as you'll note in the DIY) it's $50-$80.
Take care and enjoy the ride,
Check Codes is offline
post #3 of 3 (permalink) Old 09-04-2008, 11:08 PM
Date registered: Sep 2008
Vehicle: 1986 190E
Get yourself a crank sensor...its located rear of the engine in front of the trans...if you are standing in front of the vehicle it is on the right....held in by an E8 torx. Plug and
play and you will be good to go....take care
angelgirl5504 is offline
    2000 ML320: Cannot get it out of park and into drive usmanfar82 W163 M-Class 1 01-21-2008 02:41 PM
    Car won't start when taken for short drive. Have to wait 1/2 hr lcmlee W140 S-Class 36 01-07-2008 01:03 PM
    Belt drive noise on start-up White_Knuckles W124 E,CE,D,TD Class 3 08-17-2007 12:32 PM
    2000 E55 Fun to drive? EuroStyleAMG W210 E50 AMG, E55 AMG 7 04-13-2005 05:36 AM
    rarely used-how often should start/drive jeckie General Mercedes-Benz 4 03-08-2005 07:00 PM
