Help!! Check Engine Light on!!! - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 08-12-2008, 12:45 PM Thread Starter
autobaun1's Avatar
Date registered: Aug 2008
Vehicle: 1997 E320 Gold Package
I had my 1997 E320 for 2 years now and it never gave me a problem. Til a few days ago, I went and had a scan done and I got 2 codes come up. Codes= P0130 & P0410. What i was told by the guy who checked it for me is that it can be a variety of things( sounds like he's just ready to rip me off) So what I would like to know is this a super sensative issue or one that i can indulge in myself, I'm pretty good at fixing minor problems. Please Help me from falling into the " IT'S GONNA COST YA " trap cause the car is still riding fine but I don't want to cause any more damage then there may already be.
autobaun1 is offline
post #2 of 5 (permalink) Old 08-12-2008, 02:13 PM
MTI's Avatar
Vehicle: '85 2.3-16 '99 C280 '11 GLK350
I believe the first code is for your air filter. Have you done a "search" on the forum with those codes?
MTI is offline
post #3 of 5 (permalink) Old 08-12-2008, 03:30 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Hey, baun1, welcome to BW.
If you scroll down the forums page to the sedan sections, you'll see the W210 forum, which is specific to your car. At the top of that forum you'll see a series of "help" stickies and in there pick the one for there you'll find a post that lists all the late-model DTCs so you can find it.
Take care and I'll see you in the 210 forum,
Check Codes is offline
post #4 of 5 (permalink) Old 08-14-2008, 04:58 AM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 78 Post(s)
P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1, open circuit bef cat right)
P0410 Secondary Air Injection System Malfunction
You can do a search for more information. If it is your O2 sensor(s), change them!!!! If not your vehicle will run rich and you can have additional costly repairs.
Michael Pillay is offline
post #5 of 5 (permalink) Old 08-18-2008, 06:17 PM
benzfixer's Avatar
Date registered: Nov 2007
Vehicle: Don't own a Mercedes, probably because I fix them for a living. LOL.
First off, check your rubber vacuum lines coming out of the valve cover area and in front of the head under the black cover.
Chances are one is cracked, usually the red one.
Replace it with a comparable rubber line.
benzfixer is offline
    1997 S420 Fuel gage light flasehs setting Check Engine light aljabari W140 S-Class 7 09-03-2007 09:19 PM
    How to check code for check engine light 94 E320 W124 Synd W124 E,CE,D,TD Class 1 05-24-2007 02:37 PM
    would blown dashboard light make check engine light go on? ae98 R170 SLK-Class 3 10-07-2006 12:36 AM
    check engine light & flashing fuel guage light pd99sl500 R129 SL-Class 7 02-27-2005 04:31 PM
    Help Please!!! Check Engine Light...Empty Fuel Light Flashing mJstk01 R170 SLK-Class 6 05-18-2003 10:53 AM
