Locating Starter on E320?? - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 08-11-2008, 07:21 PM Thread Starter
Diamond_Dan's Avatar
Date registered: Aug 2008
Vehicle: 2002 E320 4matic
Question Locating Starter on E320??
I'm quite certain I have a starter solonid, issue or a loose connection near there. But...Where is there? Im guessing Passenger side of engine, but is there a reference to the location of the starter? pdf maybe? Thanks
Diamond_Dan is offline
post #2 of 3 (permalink) Old 08-11-2008, 08:03 PM
Musikmann's Avatar
Quoted: 6 Post(s)
Please come and join us on the W210 forum. There are a few knowledgeable guys on there who will be more than happy to help you.
Musikmann is offline
post #3 of 3 (permalink) Old 08-12-2008, 07:24 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Hi, Dan and welcome.
There is nothing bizarre about the starter, looks like a starter with a piggybackesd solenoid.
Pull the four lag screws (7mm hex if memory serves) for the back part of the belly pan and you will see it nestled in the back, lower right side of the engine. Spot the oil drain plug and go straight up from there and you'll see it.
You won't see it until you pull the beyy pan, though.
See you in the W210 forum...
Take care and enjoy the ride,
Greg
Check Codes is offline
E320 will not start (starter not acting) zviratko W210 E-Class 28 10-23-2016 01:35 AM
Can I Install A Remote Starter On 1998 E320?? SomeGuy07 General Mercedes-Benz 9 09-10-2016 10:39 PM
E320 - 97 How to remove Starter motor top bolt? Don Reid W210 E-Class 1 04-09-2015 09:22 AM
intermittant starter problem E320 fourthbenz W124 E,CE,D,TD Class 2 08-18-2004 03:31 PM
Starter relay? problem starting my 96 E320 gwfong W210 E-Class 2 05-24-2003 11:46 AM
