trunk lid won't lock shut - Mercedes-Benz Forum
post #1 of 18 (permalink) Old 08-09-2008, 06:54 AM Thread Starter
Date registered: Dec 2003
Vehicle: 2002 CL 500
the little motor that pulls lid closed another half inch after it;s down went out , don't know if it;s a fuse , a reset or the mechanism is just burnt. any advice ?
reliablebruce is offline
post #2 of 18 (permalink) Old 08-09-2008, 12:38 PM
Jayhawk's Avatar
Date registered: Aug 2005
Vehicle: S500/W220/2000
Are all other pneumatic devices (door looks, door closers, etc.) working okay or is it just the trunk closer? If others aren't working, then it's probably a bad air pump. But if it's just the trunk, then the dealer may need to tweak the mechanism and check to make sure it is clean and functioning. Make sure there is nothing blocking the trunk lid from closing.
Don't believe everything you think
Jayhawk is offline
post #3 of 18 (permalink) Old 08-09-2008, 01:16 PM
Musikmann's Avatar
Quoted: 6 Post(s)
Ditto to Jayhawk. It's called the PSE, and it is a pneumatic system. There is a module and a pump but I don't know what else. There is no little individual motor running the trunk close assist function.
Musikmann is offline
post #4 of 18 (permalink) Old 08-09-2008, 03:47 PM Thread Starter
thanks for input guys at least I can fully close the trunk by just pressing on it as a normal car . funny the one on my old camaro never broke.
post #5 of 18 (permalink) Old 08-09-2008, 04:56 PM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T current 2014 lexus LS460
Peter Guenther is offline
post #6 of 18 (permalink) Old 08-10-2008, 01:51 PM Thread Starter
so much for that now trunk is closed for good, mechanical key, smart key , and switch on door doesn't work what good is emergency open if it's inside of trunk now to MB dealer hope they can do something. just another MB crap box.my next car will be a six cylinder chevy pickup like a 1965.
post #7 of 18 (permalink) Old 08-10-2008, 06:01 PM
worst mod in BW history
ThrillKill's Avatar
Date registered: Apr 2005
Vehicle: ML CLK Iridescent Hyundai Accent lol,GoPed Freightshaker & Volvo semi's, c'mawn?
Quoted: 4 Post(s)
I'm willing to bet it's the trunk lid sensor (grey plastic pin ) that senses whether the lid is closed or not. It's about 9 bucks.
http://www.benzworld.org/forums/w208...-300-your.html
ThrillKill is offline
post #8 of 18 (permalink) Old 08-10-2008, 07:03 PM
RKH
RKH's Avatar
Date registered: Apr 2008
Vehicle: Departed 1998 SL500 (and the Pano is in Bogota)
Quoted: 457 Post(s)
Even with bad sensor (or for that matter with the main battery disconnected) the mechanical key should still works, so his case sounds like the mechanical parts of the trunk locking system is not working.
RKH is offline
post #9 of 18 (permalink) Old 08-10-2008, 07:29 PM
Kajtek1's Avatar
Quoted: 1163 Post(s)
There always is a dynamite.
Kajtek1 is online now
post #10 of 18 (permalink) Old 08-10-2008, 10:53 PM
Diesel Benz's Avatar
Quoted: 35 Post(s)
The issue was not opening the trunk lid but closing it fully, if I got it right. You should not need the mechanical key when closing it. An he already explained it does close when operated like a normal trunk lid (slam it closed).
The auto-closure system would not work without battery power, you cannot judge if it is electronic or mechanical when the battery was disconnected.
I'd follow the good advice given so far (don't try the latest advice from Kajtek1 first ).
PS. did the Camaro have a trunk closing aid feature? If not, I'm not surprised it did not get broken. In any case, I've worked on one very long time ago and fixing it was not too complicated).
Diesel Benz is offline
    Trunk refuses to POP open due to lid lock mechanism Prvteye R129 SL-Class 55 02-18-2014 04:47 PM
    Trunk lock is not working Trunk locked shut Type 4 R/C107 SL/SLC Class 19 02-15-2013 09:30 PM
    Trunk wont open by dash button or remote due to lid lock mechanism smokey007 R129 SL-Class 9 08-08-2008 09:54 PM
    Trunk lid lock disassembly? shingleback W201 190-Class 5 07-21-2006 03:16 PM
    Trunk Lid Won't Lock Doug R170 SLK-Class 1 04-27-2002 04:40 PM
