Limp mode? - Page 2 - Mercedes-Benz Forum
post #11 of 54 (permalink) Old 08-09-2008, 12:27 PM Thread Starter
worst mod in BW history
ThrillKill's Avatar
Date registered: Apr 2005
Vehicle: ML CLK Iridescent Hyundai Accent lol,GoPed Freightshaker & Volvo semi's, c'mawn?
Quoted: 4 Post(s)
Ok, I pulled P0141 which is an O2 sensor. Could this cause the slowness?
ThrillKill is offline
post #12 of 54 (permalink) Old 08-09-2008, 12:31 PM Thread Starter
ThrillKill's Avatar
Quoted: 4 Post(s)
Found this on the web.
The HEATER CIRCUIT MALFUNCTION error means that the built-in heater inside
the sensor has failed. The only recovery from this is to replace the
affected sensor. Having said that, this is not an error that should result
in your car shutting down.
The sensor works when it has reached a certain temp. This temp will easily
be reached through the passing of the exhaust stream, but the rise-time is
too slow. The computer wants to see a valid input faster than exhaust stream
will heat the sensor -- the problem here is that the sensor is needed to
reduce smog, and a cold sensor will not reduce smog so they heat it by
internal means to get it to work. The internal heater is broken.
Neither code you reported should shut the car down. Of the two, the second
might result in the car reverting to Limp Mode, where it runs crappy -- and
rich (too much gas is fed).
post #13 of 54 (permalink) Old 08-09-2008, 12:33 PM
Jayhawk's Avatar
Date registered: Aug 2005
Vehicle: S500/W220/2000
I think that is your MAF, and yes it can cause slowness--and worse. It also could be cat-related but I think it more likely a dirty/bad air flow sensor. If you follow the MBSearch threads you will see it is probably a relatively easy fix. They say it's a DIY, but I have my dealer do it.
Don't believe everything you think
Jayhawk is offline
post #14 of 54 (permalink) Old 08-09-2008, 12:38 PM
Jayhawk's Avatar
Those codes are notoriously unreliable and often erroneous. It is kind of like a CEL: It can mean almost anything. See if your dealer will give you a professional reading. Should be free I believe...
Jayhawk is offline
post #15 of 54 (permalink) Old 08-09-2008, 12:42 PM Thread Starter
ThrillKill's Avatar
Quoted: 4 Post(s)
Well I've changed out the MAF on the ML. In a very tight spot but doable. The thing is I just recently checked all my cars for codes 2 weeks ago when I was working on the ML and came up with nothing so this seems to be very related. Plus it is even showing me which bank and what sensor.
post #16 of 54 (permalink) Old 08-09-2008, 12:51 PM
Jayhawk's Avatar
Let us know what you do and what happens... I'm curious. Do you have a lot of particulate matter in the air where you drive and/or park your cars?
Jayhawk is offline
post #17 of 54 (permalink) Old 08-09-2008, 12:57 PM Thread Starter
ThrillKill's Avatar
Quoted: 4 Post(s)
No, not really. I put only about 30 miles on it per week and this happened all of a sudden. There was absolutely no performance issue prior to this.
post #18 of 54 (permalink) Old 08-09-2008, 01:04 PM
Jayhawk's Avatar
Strange... But our cars have a nasty habit of crapping-out when left to sit for more than a few days.
Jayhawk is offline
post #19 of 54 (permalink) Old 08-09-2008, 01:04 PM Thread Starter
ThrillKill's Avatar
Quoted: 4 Post(s)
Dealer wanted double for what I can get it for at NAPA. Darn crooks.
post #20 of 54 (permalink) Old 08-09-2008, 01:24 PM
Jayhawk's Avatar
A guy over at MBCA has the same issue: SLK Hesitation - Mercedes-Benz Club of America Forums Except he pulled P0170...
You might want to see what he does...
Jayhawk is offline
    Limp Mode noelchambers R170 SLK-Class 4 08-18-2008 01:27 PM
    LIMP MODE V-TECH W203 C-Class 0 06-27-2008 12:43 PM
    LIMP MODE djblu R129 SL-Class 12 08-14-2007 05:21 PM
    limp mode??? Dolphin27 R170 SLK-Class 1 01-04-2006 03:02 PM
    What is "limp mode"? xraider W202 C-Class 1 02-23-2004 05:20 AM
