E430 A/C Problem - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 08-06-2008, 12:54 PM Thread Starter
Date registered: Jun 2008
Vehicle: 2000 Mercedes E430
E430 A/C Problem
I have a 2000 E430 and I got a weird problem with the A/C. The right vents in the front blow up pretty cold air while the left ones do not. I have noticed the hissing noise coming from the middle vents which I have read on here is supposed to indicate low refrigerant. I have performed the diagnostics test a while ago and everything seemed ok besides a sensor. Any ideas?
ali7288 is offline
post #2 of 4 (permalink) Old 08-06-2008, 03:13 PM
RKH's Avatar
Date registered: Apr 2008
Vehicle: Departed 1998 SL500 (and the Pano is in Bogota)
Quoted: 443 Post(s)
If you have good cold air, the refrigerant should be OK.
Replace that sensor. Then try again to see if everything works.
RKH is offline
post #3 of 4 (permalink) Old 08-06-2008, 04:49 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Hi, Ali, welcome to the forum, please use the user cp link to update your profile re: vehicle and location as that is useful information when you're seeking help.
Come join us in the W210 forum, that's the one native to your car: W210 E-Class - Benzworld.org - Mercedes Benz Discussion Forum
At the top of that forum you'll find lots of help stickies, including the one to the diagnostic tools (perhaps the one you ran previously). It's easy enough to run so read through that and run it, then post the results in the 210 forum and the folks there will help you out. That's much better than just trying to figure it out from symptoms, which in your case could be a sensor, a duo valve or low refrigerant (or perhaps more than one).
Take care and enjoy the ride,
Check Codes is offline
post #4 of 4 (permalink) Old 08-07-2008, 12:53 PM Thread Starter
ok thank you, i will run the diagnostics tool again on the weekend when i have time. yes i have ran the same diagnostics test previously. i will post the results on the w210 forum when i run the test.
ali7288 is offline
    Serious problem with E430- Please Help Karansav W210 E-Class 3 03-18-2008 10:10 AM
    Need help with E430 Problem FSBenz W210 E-Class 2 12-21-2007 08:01 PM
    98 E430- starting problem-what could this be? silvervault430 W210 E-Class 34 08-30-2007 09:28 AM
    98 E430 A/C Problem(s) Musikmann W210 E-Class 26 06-04-2006 08:07 PM
    E430 Starting Problem Tom Rallye W210 E-Class 0 01-08-2006 09:23 AM
