Leaking Brake Line - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 08-05-2008, 06:35 PM Thread Starter
Date registered: Jul 2008
Leaking Brake Line
I noticed that the brake fluid reservoir in my E420 has been going down as of late. So I looked under the car to find a wet spot above the exhaust pipe just in front of the rear axle. I'm sure the line needs replacing and I'm considering doing it. Looking at other threads, I hear that the suspension needs to be dropped. With good mechanical skills and basic tools, I wondering if I can reroute the line/lines in question to avoid having to do this given I'm working with a jack and jack stands. I think I might buy the line/lines from the dealer already flared to avoid the tooling. I'm counting on the 11mm nut attaching the line to the hose to be stubborn but hoping . I have a question about the line/lines supplying the rear brakes. Is it 1 line with a T or are there 2 separate lines? My DIY thinking and budget says think about it but some threads are telling me otherwise. I'm also curious what this will cost if I do it versus the stealership. On a difficult scale out of 5, what would this rate?
jgeorg is offline
    Leaking Brake Line jgeorg W124 E,CE,D,TD Class 0 08-05-2008 06:29 PM
    leaking oil cooler line pika W123 E,CE,D,CD,TD,TE Class 1 01-29-2005 06:54 PM
    leaking oil cooler line pika W124 E,CE,D,TD Class 0 01-28-2005 06:54 PM
    my fuel line is leaking alot in the rear of the car classic benz W126 S,SE,SEC,SEL,SD,SDL Class 1 04-26-2004 09:48 PM
    Leaking vacuum line and tranny SKullman W123 E,CE,D,CD,TD,TE Class 4 02-10-2004 01:59 PM
