fuel pump regulator? - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 08-05-2008, 10:37 AM Thread Starter
Rauchen's Avatar
Date registered: Jul 2008
Vehicle: 1971 Mercedes 280sel (w108)
My 1971 280 sel seems to pump too much gas at times to my carb. After about a 10 mile run, especially pulling hills and so forth, if I turn the car off, it will then flood the carb. So then before I can restart the car, I have to air out the carb to get it started again. I was wondering if this could be helped by adjusting the flow from the fuel pump? It is, however, an after market AC spark fuel pump. But I don't know if these have an adjustment or if I could get some type of inline regulator or if I am just way off base with this.http://www.benzworld.org/forums/imag...s/confused.gif
Rauchen is offline
post #2 of 3 (permalink) Old 08-05-2008, 10:43 AM
Diesel Benz's Avatar
Quoted: 32 Post(s)
Shouldn't the fuel pump just keep sufficient fuel pressure at the carburettor input and the carburettor itself should have a float controlling the fuel level. Perhaps the needle does not hold the pressure well enough?
Diesel Benz is offline
post #3 of 3 (permalink) Old 08-05-2008, 12:25 PM
Vehicle: 2005 C230 K
It's possible the float is getting stuck open. The fuel pump is there to keep a constant flow of fuel (pressure) going to the carb then the float controls the fuel. Maybe there is a adjustment screw (air/fuel mix) that will allow you to adjust the float controlling fuel flow into the carb. It is also possible the fuel pump is pushing to much pressure. It may be rated more then the stock unit.
MelloC230 is offline
    Smelling Fuel - Change Gaskets at Fuel Regulator? davidby R129 SL-Class 0 04-03-2007 10:51 AM
    Fuel regulator ak380sec General Mercedes-Benz 0 02-22-2006 06:52 PM
    Fuel pump/regulator question euroamg W123 E,CE,D,CD,TD,TE Class 6 10-04-2005 06:04 PM
    380sel where is the fuel pump fuse? have no power to pump meggala W126 S,SE,SEC,SEL,SD,SDL Class 3 08-02-2005 03:44 AM
    280E: Fuel to Cold Start Injector, but not to main injectors - Fuel Press. Regulator? or other?? GermanCarNut W123 E,CE,D,CD,TD,TE Class 0 01-25-2004 03:12 PM
