Car operating very hot after repair - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 08-02-2008, 06:54 AM Thread Starter
Date registered: May 2008
Last week my engine overheated after the radiator leaked and all the
water poured out of the cooling system.
I had a new radiator installed and all the damaged parts repaired in
the engine (head gaskets, glow plugs, oil, thermostate, etc). Damage
was pretty bad. The mechanics didn't see cracks in the block.
The car works after the repairs, BUT, it's running very hot. At idle
the temp gauge sits at 90 C, driving on city streets or at highway
speed (65-75mph) the temp gauge is at 110 C. If I put the A/C on the
gauge goes just a smidge below 120 C (which is the overheat mark). So
the car doesn't technically over heat but it is running hot without
the A/C on. If I had the A/C on it would probably over heat.
After a 20 minute test drive with no A/C on, and the gauge at approx
115 C the whole time, I got home and opened the hood. Lots of heat and the water in the bottle was boiling and hissing out of the bottle cap.
Any ideas what's going on? Car used to run at 80-85 C before the repairs.
johnhere is offline
post #2 of 3 (permalink) Old 08-02-2008, 07:33 AM
E-Class Owner's Avatar
Vehicle: 2003 Mercedes Benz E500
You did not...
indicate your car's model and year, or your location; these items are important in helping you sort out your problem. What is the ambient temperature when the car gets hot?
If sounds like the cooling system is not pressurizing, possibly from a faulty cap on the expansion tank, possibly from other problems.
If the car is a W124, the brass filler neck often looses its seal where it attaches to the expansion tank, causing the symptoms you describe.
You should consider taking the car back to the shop that did the repairs; they should be able to diagnose the problem.
E-Class Owner is offline
post #3 of 3 (permalink) Old 08-02-2008, 09:03 AM
Musikmann's Avatar
Quoted: 5 Post(s)
+1 That's what I would do too. The shop should have some sort of warranty on work they perform.
Musikmann is offline
    Car just dies when at operating temperature Bawbag R129 SL-Class 2 02-16-2007 03:57 AM
    250SL for PRO PHOTO SHOOT - Hot car for our hot model hilnix Vintage Mercedes-Benz 0 11-07-2006 03:51 PM
    Car dies at operating temperature SubieHo W201 190-Class 4 09-20-2006 06:24 AM
    hot car - hot girl - hot video ;p krk230 R170 SLK-Class 7 07-31-2005 01:07 PM
    is 80- 95 deg. celsius , Nornal Operating Temp. or Too Hot? spine911 W210 E-Class 8 11-22-2004 04:41 AM
