Service A @ 60000 miles : @2000 E320 - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 08-01-2008, 11:04 AM Thread Starter
Date registered: Aug 2008
Hi,
I have a 2000 E320 with 60000 miles on it. Service A is due on it now.
i took it to the dealer and he recomended the following
- Antifreeze Flush
- Brake Fluid Flush
- Fuel Filter change
- Air filter change
I also called a german car mechanic and he remomended all of the above plus the following
- spark plug and wiring
- carbon filters
I am now confused as to what needs to be actually changed.
i am of the opinion that ..If it aint broke...dont fix it..
Any comments on what should i get done
sidman is offline
post #2 of 6 (permalink) Old 08-01-2008, 11:23 AM
Musikmann's Avatar
Quoted: 6 Post(s)
It partly depends on your service history. MB recommends changing your coolant every 3 years and your brake fluid every 2 years. As far as I know there is no recommended interval for a fuel filter. The cabin air filters might be due as is the engine air filter. Your spark plugs are supposed to last 100,000 miles so unless you have symptoms, I would not have those changed yet.
Musikmann is offline
post #3 of 6 (permalink) Old 08-01-2008, 11:38 AM Thread Starter
thanks for you response...
i have been punctual with my services so far. its just the dealer is asking 130$ each for the fluid flushes...
I have ahd the car for about 2 years now and am the second owner...
the car only had 20000 miles when i bought it...its only driven about 3-4 k/ year...
sidman is offline
post #4 of 6 (permalink) Old 08-01-2008, 12:56 PM
joshuajeeper's Avatar
Date registered: Sep 2006
Vehicle: 1985 Mercedes 300TD, 2014 GLK250 Bluetec
For a 2000 E320, the recommended services are as followed:
Dust filter (aka cabin filter) every B service
Engine air filter every 4 years or 60,000 miles (which ever comes first)
Fuel filter every 5 years or 60,000 miles (which ever comes first)
Charcol filter every 5 years or 60,000 miles (which ever comes first) if your car is equiped with them.
Brake fluid flush every 2 years
Coolant flush every 3 years
and spark plugs every 5 years or 100,000 miles (which ever comes first)
Also I'd recommend even doing a transmission service every 35,000-40,000 miles too. Saves the transmission in the long run.
Hope that helps.
1985 300TD - "Panzer Wagen" - undergoing full restoration (resto - mod)
2014 GLK250 Bluetec (Wife's Car)
Mercedes-Benz Master Certified Technician.
http://www.flickr.com/photos/joshuajeeper/
joshuajeeper is online now
post #5 of 6 (permalink) Old 08-01-2008, 12:59 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
That's way too much for the flushes, but pretty much in line with the stealer. These cars will eat you alive if you don't DIY. But if you have the money, more power to you.
Agree with MM, you don't need plugs until 100K. However, you didn't mention the AT service (fluid and filter change) and you are in the range for that.
Come join us in the home forum for your car, the W210. You'll find lots more info there.
Take care and enjoy the ride,
Greg
Check Codes is offline
post #6 of 6 (permalink) Old 08-01-2008, 02:23 PM
Musikmann's Avatar
Quoted: 6 Post(s)
Ditto to Greg on 3 counts:
1) Dealer will be expensive for brake fluid and coolant flush (been there, done that).
2) Service your transmission soon.
3) Please join us on the W210 forum.
Not that it's right, but I have the original fuel filter at over 72,000 miles. One dealer I asked said the same thing Joshua did: 5 years or 60,000. Mine is more flexible and I've never seen that in writing from MB. I'm also told the most common symptom of a partially clogged fuel filter is engine hesitation climbing hills.
Good luck.
FS: 2000 E320 with only 47K miles olivengco For Sale/Wanted/Trade/Giveaway 0 12-26-2006 10:59 PM
FS 2000 E320 4Matic 23k Orig Miles chad103998 For Sale/Wanted/Trade/Giveaway 0 02-03-2006 12:31 PM
2000 E320 4Matic 23k Orig Miles chad103998 For Sale/Wanted/Trade/Giveaway 0 02-03-2006 12:28 PM
60000 Miles Service ulflei W140 S-Class 12 12-05-2005 02:25 PM
97 E320 30K miles service az2md W210 E-Class 8 05-29-2003 11:34 AM
