2002 c 230 check engine light and srs light - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 07-31-2008, 07:13 PM Thread Starter
Date registered: Dec 2007
Vehicle: 2002 ML 320
does anyon eknow the most typical cause of the check engine light om a c 230 year 2002 about 100,500 miles on it.. just came on...also the srs light has been on a while.
It only comes on when I use the driver side seat belt... when the passenger is belted and driver is not.. it stays off... as soon as the driver side is inserted it comes on.. any suggestions for an inexpensive fix on this?
upstaterider2003 is offline
post #2 of 5 (permalink) Old 08-03-2008, 09:48 AM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 91 Post(s)
Get the codes read. Autozone or Advance Auto will do it for free.
Mike
Michael Pillay is offline
post #3 of 5 (permalink) Old 08-03-2008, 10:05 AM
carminemb82's Avatar
Date registered: Mar 2006
Post
first you must obtain the fault codes.
Common problems:
the cam adjustment solenoids can leak engine oil. the oil then wicks its way into the engine wiring harness giving you fault codes for 02 sensors, maf, or sometimes even a code for faulty engine control unit. Inspect the solenoid and engine electrical connectors for oil.
a faulty seat belt buckle with give you a SRS fault.
carminemb82 is offline
post #4 of 5 (permalink) Old 08-03-2008, 10:47 PM
Date registered: Jun 2004
Vehicle: 2008 c350, 2004 c240
At that mileage it's quite typical to see O2 sensors fail.
You're wasting your time without a code scanner though.
wblynch is offline
post #5 of 5 (permalink) Old 08-04-2008, 07:35 AM
Quoted: 91 Post(s)
Harbor Freight had one on sale for $40 or so not too long ago.
Mike
2002 - C240 check engine light+rough idle (again) Thom Russell W203 C-Class 4 03-05-2008 06:34 PM
1997 S420 Fuel gage light flasehs setting Check Engine light aljabari W140 S-Class 7 09-03-2007 09:19 PM
Check Engine Light / Car Stalls @ Stop Light jasonryan11 R171 SLK-Class 2 08-03-2007 06:56 AM
C 230 engine shaking real bad, check engine light on.Please Help!!!! ammar_rage W203 C-Class 7 06-02-2007 01:05 PM
would blown dashboard light make check engine light go on? ae98 R170 SLK-Class 3 10-07-2006 12:36 AM
