1988 300CE STALLED IN TRAFFIC AND WON'T START - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 07-30-2008, 05:18 PM Thread Starter
Date registered: Jul 2008
Vehicle: 1988 300CE
Hi there. I'm new to the site, if anyone can help me, that would be great....
A few days ago I started my car (it was already warm) and it stalled right after it started. I started it again and no problems.
The following day I started it and it idled rough like it wanted to stall. Once it got warm and drivin it appeared to be running fine. I got into some downtown traffic and it stalled and hasn't started since (I got it towed home).
It turns over strong but won't start. I am guessing that maybe it is either the crank sensor, fuel pump, fuel pump relay or fuel filter....but I'm only guessing, I don't have any experience with this model (it has the 3.0L inline-6). I have only owned a 87 190E 2.6 and a 99 ML430.
If anyone has any advice, it would be greatly appreciated!!!
It has 240,000kms (dealer maintained)
Benzy B is offline
post #2 of 6 (permalink) Old 07-31-2008, 06:25 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
If you have experience with the 2.6, you current steed isn't all that different. Can you hear the fuel pump at all?
flyboyike is offline
post #3 of 6 (permalink) Old 07-31-2008, 07:10 PM Thread Starter
Vehicle: 1988 300CE
Thank You for your response!
Yes, I hear the fuel pump(s). Does that mean that the fuel pump(s) are ok?There is two of them. If one of them is done, will I still not be able to start it?
Do you know a good way to test the fuel pump(s)? I heard I could spray carb cleaner in the air intake tube while the engine is being turned over and if it ignites, it is the fuel pump(s).
Thanks for your time!
Benzy B is offline
post #4 of 6 (permalink) Old 08-02-2008, 10:40 PM Thread Starter
Vehicle: 1988 300CE
Any suggestions out there?
If anyone has any suggestions, please reply. thanks!
Benzy B is offline
post #5 of 6 (permalink) Old 08-03-2008, 08:12 AM
Musikmann's Avatar
Quoted: 6 Post(s)
Try replacing the crankshaft position sensor.
Musikmann is offline
post #6 of 6 (permalink) Old 08-03-2008, 10:23 AM Thread Starter
Vehicle: 1988 300CE
Would it show a code?
If it is the crankshaft position sensor, would it show a code?
I had the CPS go on my 99 ML430 before I sold it, it had 225,000kms on it, so you may be right! What about rough idling the morning it stalled, would the CPS cause that too?
Thanks for your reply.
Benzy B is offline
    95 S420 stalled, won't start anymore! johnson154 W140 S-Class 6 12-21-2011 02:49 AM
    1988 300CE STALLED IN TRAFFIC AND WON'T START Benzy B General Mercedes-Benz 0 07-30-2008 05:14 PM
    1988 300CE ehpotsirhc W124 E,CE,D,TD Class 2 07-03-2008 10:31 AM
    engine stalled and won't start right away pete168 W201 190-Class 2 11-21-2002 06:53 PM
    300CE running warm in traffic...100-110degree Hai Hoang Phan W124 E,CE,D,TD Class 5 09-10-2002 09:21 AM
