Automatic Transmission vrs Manual Transmission - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 07-27-2008, 04:13 AM Thread Starter
Date registered: Jul 2008
Vehicle: M/Benz 200 E
Send a message via Yahoo to gentletyphoon
Can someone please tell me which is more fuel efficient the Automatic Transmission or the Manual Transmission. I am contemplating getting a M/Benz 200E.
gentletyphoon is offline
post #2 of 3 (permalink) Old 07-27-2008, 05:06 AM
xntrek's Avatar
Vehicle: C220 CDI with OPTIONS!
You know, it's not as simple as "which transmission is better?".
For example, what kind of driving do you do? if you're mainly a "performance driver", you'll probably want to stick to a manual and gain some of that power. But if you're a commuter who doesn't want to shift those gears on the drive home, go with an automatic. If you'll be dealing with slopes, mud and/or rain a lot then you'd probably want a manual. You get the idea...
As for fuel efficiency, it really depends on how you drive and the age of the automatic. Theoretically, if you are a "sensible" driver with good control, then you can have far greater fuel efficiencies with a manual. However, more modern automatics can change gears faster, more efficiently and save more fuel than most drivers in control of an manual.
At the end of the day, I'd suggest choosing a transmission on your driving style first, which will be weighed by a bias of your own preference anyway - then worry about the fuel savings later - in most cases the differences are minor. I think the average combined mileage of a 91 200E are along the lines of 22 mpg (11 l/100km).
"Look Pa! I contributed absolutely nothing to that there thread!"
Cubanite Silver C220 CDI Avantgarde with the lot ...
xntrek is offline
post #3 of 3 (permalink) Old 07-27-2008, 07:08 AM
Crazyjester900's Avatar
Vehicle: Mercedes-Benz 1996 C200 W202
auto
Crazyjester900 is offline
    Convert automatic transmission to a manual manick W201 190-Class 4 11-21-2007 06:58 AM
    Automatic to manual transmission swap ButteryBenz W201 190-Class 7 12-06-2005 01:00 PM
    Prefacelift SLK: shift-knobs for automatic transmission can be installed on manual transmission? Marcello (Piacenza - R170 SLK-Class 3 04-26-2002 11:05 AM
    Is it possible to change Manual transmission to Automatic T? j R170 SLK-Class 2 03-07-2002 06:30 PM
    Manual or Automatic Transmission? Brian G R170 SLK-Class 7 06-13-2001 10:24 AM
