Did my engine blow up / engine gone? - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 07-26-2008, 10:59 PM Thread Starter
Date registered: May 2008
Driving on the interstate tonight at 75mph I look down at my temp gauge on the dash and it's off the charts into the red. I have a digital water temp gauge also that I put on and it shows normal (about 190 F). So I think the gauge is wrong as I've had electrical issues with the instrument cluster.
Well after 5 minutes or so the engine just stops dead. I pull over and open the hood and I'm blased with white smoke and the stench of what I can describe as a burning plastic smell. Had the car towed home. Oil level full. Water resevoir full. When I try to start the engine it doesn't sputter or jump or turn over or crank. Just sounds like "veeeveeeveeeveeeveee" until the started drains the battery.
Did I blow the engine? It looks physically fine from the outside.
1991 350 SD
158k miles
johnhere is offline
post #2 of 3 (permalink) Old 07-27-2008, 07:54 AM
Date registered: Feb 2008
Vehicle: 2004 W220 (S430) ; 2001 R129 (SL500) Sport
Location: Alabama Gulf Coast--formerly Charlottesville, VA
I can't say whether your car has cooked the motor, but I had a similar experience in a SAAB 9000. The symptoms were exactly the same as you describe; no piston hanging out the side of the block, no puddle of oil or coolant--just dead. The oil pump had packed up and the engine was seized. No repair possible--replace the motor or junk the car. I hope that's not what happened to you.
"Don't pick a fight with an old man. If he is too old to fight, he'll just kill you."--John Steinbeck
DrJfrmLA is offline
post #3 of 3 (permalink) Old 07-27-2008, 10:46 AM
Jayhawk's Avatar
Date registered: Aug 2005
Vehicle: S500/W220/2000
Wow! Can't imagine what happened, but please let us know when you find out...
Don't believe everything you think
Jayhawk is offline
    Engine Blow on 10 day old SLK200 beverage R171 SLK-Class 4 02-01-2006 08:22 AM
    what are the signs to watch if your engine will blow by? red_dragon W124 E,CE,D,TD Class 5 08-08-2004 03:28 AM
    engine blow-by zoran W123 E,CE,D,CD,TD,TE Class 3 08-07-2004 11:59 AM
    is there anywhere on a 230 engine where i could custom fit a blow-off valve? SilverSport R170 SLK-Class 16 02-01-2002 01:21 AM
    WHAT CAUSES ENGINE BLOW -BY? Guest (MBNZ) W123 E,CE,D,CD,TD,TE Class 3 03-31-2001 05:49 PM
